It is currently Sat May 25, 2013 9:53 pm
Carver MX130 Problem??
fishfun83
Post Tue Sep 18, 2012 1:52 pm
I just robbed my attic and took down my vintage MX130 Receiver. What I noticed, when I attached my speakers, was that the left speaker didn't kick in until I turned up the volume. Then everything worked as it should. Is this a problem and should I send it in for repair? Thanks and any help will be greatly appreciated.
Post Tue Sep 18, 2012 2:49 pm
Re: Carver MX130 Problem??
Shoot the volume pot with Caig DeOxit & Work back and forth several times.
Post Wed Sep 19, 2012 7:43 pm
clean the relays also
fishfun83
Post Wed Sep 19, 2012 9:28 pm
Looks to me like the relays are sealed. Can you still somehow clean them?
Thanks
Post Thu Sep 20, 2012 3:36 pm
Yes: unseal them! :lol:
Seriously, I don't know. But if they ARE sealed, I'd leave them that way...
67ih4x4x4
Post Fri Sep 21, 2012 9:55 am
The relays are a problem with the mx130. You can buy replacements online if you determine that they are the problem. I just did a set myself, not bad at all to replace.
