It is currently Sun May 26, 2013 1:19 am
Carver Tfm 35 question
conrad
Post Sun Feb 15, 2004 9:20 pm
I know the TFm 35 in mono at 8 ohms gives 700 watts....but is it advisiable to try to run this amp bridged in 4 ohms?I have a subwoofer that is rated at 4 ohms ...but the Carver Manual doesn't say anything about bridged 4 ohms ..what do you guys think is it possible without hurting the amp?
George
Post Mon Feb 16, 2004 8:58 am
I think your fear may be justified. A call to Carver Repair may be in order before driving a 4 ohm sub with a bridged TFM-35. Perhaps they can give you the definitive yes or no.
conrad
Post Wed Feb 18, 2004 7:13 pm
I can't beleive in a forum dedicated to Carver equipement...I can't get one answer on this.........
Post Wed Feb 18, 2004 8:43 pm
It will only drive a 8 ohm load bridged.
boomer-X
Post Wed Feb 18, 2004 9:48 pm
I was just reading in my TFM-35X manual last week about bridging them and it specifically warns not to run 4 OHM speaker(s) in this configuration because it can lead to overheating and internal circuit protection shutdown.
conrad
Post Wed Feb 18, 2004 10:42 pm
Thanks guys...too bad it's cant' run in this way...but thats asking too much... right now I'm running two 15 inch 8 ohm subwoofers with it....I wanted to run a single 4 ohm 18 incher with it.I will go back to plan B and run two 4 ohm 15 inchers......any of you guys use it in stereo configuration in 4 ohms?That should be okay?
tinear
Post Sat May 01, 2004 9:28 pm
I've used a TFM 15CB in the past with two 12 inch 4ohm subs ( titanic's). The amp always ran cool and never presented a problem.
