It is currently Sat May 25, 2013 11:55 am
Carver TFM amps for bi-amping/tri-amping
Post Thu Nov 08, 2012 6:40 pm
Re: Carver TFM amps for bi-amping/tri-amping
If you want the tube sound, and with horns you should, then get tube amps.
Post Thu Nov 08, 2012 11:41 pm
I would say they have tube like warmth but that's where it begins and ends.
Post Fri Nov 09, 2012 8:31 am
Im thinking about tri-amping a system myself when my little CF tube amps arrive. I think your tfm amps would work great with this setup. Best thing to do is try it out and let us know how it works. I have bi-amped with tfms and they sounded great!
Lightstar serial #0008
400x7
300x2
SD/A 490t
Sunfire Tube preamp
ProJect TT Tube preamp
JL Audio 12W7's
Post Sun Nov 11, 2012 7:06 pm
F1nut wrote:If you want the tube sound, and with horns you should, then get tube amps.
=D> =D> =D> =D> =D>
On a different note.....the overall quality of the sound you get out of your system will depend upon the crossover frequencies in relationship to the drivers you are using along with the quality of the crossover and determining the correct slopes.
