It is currently Fri May 24, 2013 3:41 am
CHERRY 25 CLASS A Tube Amp on eBay
Post Wed Feb 27, 2013 8:40 pm
New tube amp design, wonder how one of these would sound on my Klipsch's?? =P~ =P~ =P~
http://www.ebay.com/itm/CHERRY-25-CLASS ... 2a29e07dae
Post Fri Mar 01, 2013 1:42 am
Re: CHERRY 25 CLASS A Tube Amp on eBay
2 x 5 watts
Post Fri Mar 01, 2013 1:55 am
"2 x 5 watts"
Benefit: no "light dimming" problems! :lol:
Or: "The amp for the man with a VERY big penis" :lol: :lol:
jk: I'm sure it sounds heavenly..at moderate listening levels and with efficient speakers!
Post Fri Mar 01, 2013 2:15 am
My speakers are 101db at 1 watt, so 107db at 4 watts? :-k :-k I modified my speakers so they're bi-ampable now so maybe just use this on the horns? It would be interesting to try for sure... 8) 8)
Post Fri Mar 01, 2013 10:47 am
This looks very nice, I'll bet it would sound nice on a nice full range set up. Jesse, you need to quit fooling around and get a Baby Black Beauty. Then you will be done buying tube amps....at least until you want to trade up to a pair or Cherry 180's :lol:
Post Fri Mar 01, 2013 11:36 pm
Me thinks VOTT
