CF Amp Mods
Re: CF Amp Mods
Post by Zoot Horn » Thu May 09, 2013 8:08 am
Could not find/get any Blackgates,, so I'll be installing some OS-cons (100UF) electrolytics to replace the ones in her for cathode bias. Easy-peasy!
Re: CF Amp Mods
Post by Zoot Horn » Sat May 25, 2013 10:22 am
Os-cons (sanyo electrolytics) are in,,I'll post a pic-- gonna put some power on it-- stat tuned.
Re: CF Amp Mods
Post by Magnaryder » Sat May 25, 2013 11:58 am
Zoot Horn wrote:Os-cons (sanyo electrolytics) are in,,I'll post a pic-- gonna put some power on it-- stat tuned.
Stayin' tuned brother!! Can't wait to hear....so to speak 8)
Re: CF Amp Mods
Post by Zoot Horn » Sat May 25, 2013 5:51 pm
Well,, I am impressed with the detail and speed at low volume,,so I cranked it up a bit and I get some funky sounds,,,check tubes,,, check my solder connections,, problem still persists,, agonize for about a hour-- pull the amp,,everything appears fine-- then I spot it,, seems as though I forgot to replace the jumpers on the speakers after I pulled the ones from Dougs' cable tour--- anxiety now diminished,, the detail that the puppy is puttin' out is incrediable,, sweet sound I say,, in my best Foghorn Leghorn voice-- damn,, this is nice--and yes Ray,, I have some xtra caps left for you and Harry(if ya'll want em). Life is good!!
Re: CF Amp Mods
Post by Magnaryder » Sat May 25, 2013 6:59 pm
Zoot Horn wrote:Well,, I am impressed with the detail and speed at low volume,,so I cranked it up a bit and I get some funky sounds,,,check tubes,,, check my solder connections,, problem still persists,, agonize for about a hour-- pull the amp,,everything appears fine-- then I spot it,, seems as though I forgot to replace the jumpers on the speakers after I pulled the ones from Dougs' cable tour--- anxiety now diminished,, the detail that the puppy is puttin' out is incrediable,, sweet and juicy like these nutz. sound I say,, in my best Foghorn Leghorn voice-- damn,, this is nice--and yes Ray,, I have some xtra caps left for you and Harry(if ya'll want em). Life is good!!
Damn George, speaking for Harry and myself..... thanks for the offer!! And YES I'll take some.
Re: CF Amp Mods
Post by Magnaryder » Sat May 25, 2013 9:34 pm
for the past couple of weeks one of my CF amps had been acting up. POS cat bumped one of the tubes. Tonight I took it out to the garage and flowed all of the solder joints on that side of the amp and all is well. Hot damn!!!!
Re: CF Amp Mods
Post by Zoot Horn » Sun May 26, 2013 6:52 am
I'm talking electrolytic's for the input tubes(2 per amp),,, easy swap, I have enough for 3 amps.
Re: CF Amp Mods
Post by Magnaryder » Sun May 26, 2013 12:35 pm
You da man George!!
THANKS!!!!!
Re: CF Amp Mods
Post by hewlew1 » Sun May 26, 2013 3:38 pm
Sure thing George Bring them along to the fest. Thanks
I did find the parts to mod your second amp George.
Re: CF Amp Mods
Post by Zoot Horn » Sun May 26, 2013 3:39 pm
Thank you sir !!!
Re: CF Amp Mods
Post by Magnaryder » Sun May 26, 2013 8:53 pm
What input tubes are y'all using in your CF amps?
Is the 12 volt conversion a good idea?
Re: CF Amp Mods
Post by hewlew1 » Sun May 26, 2013 9:36 pm
I still have the 6AX7's in mine if it gets to the point where i cannot find any of those I will do the conversion.
Re: CF Amp Mods
Post by Zoot Horn » Sun May 26, 2013 10:23 pm
6 volt
Re: CF Amp Mods
Post by Magnaryder » Mon May 27, 2013 12:16 am
Magnaryder wrote:What input tubes are y'all using in your CF amps?
I guess what I meant to say is what brand tubes are you using?
Re: CF Amp Mods
Post by Zoot Horn » Mon May 27, 2013 7:23 am
Russian 6n2p and Sovtek 6BQ5/El 84-- no issues,,per Tom's(VHF) suggestion,I'm in the process of obtaining some 7189's
