How do I tell which receiver I have?
lipwak
Post by lipwak » Wed May 29, 2013 4:19 pm
Hi,
I received a Carver receiver from a friend. I don't know which model it is. How can I tell? The manual was published in 1983. It appears to be a MXR-150. The specs on that say it has 150 watts output. My manual says it has 130 watts. I haven't compared all the specs but they look visually the same.
I don't see a model number on the unit. It has a serial # K 41001376.
Thanks for any help. I'd be happy to supply any other info but don't know what is needed at this point.
Cheers,
John L
Re: How do I tell which receiver I have?
Post by kingman » Sat Jun 01, 2013 12:39 pm
Can you post a picture??? It would help.
lipwak
Post by lipwak » Sat Jun 01, 2013 12:51 pm
Post by kingman » Sat Jun 01, 2013 2:31 pm
MXR-150.
lipwak
Post by lipwak » Sat Jun 01, 2013 2:38 pm
Thanks! Any recommendations on a good way to clean the front? Isopropyl alcohol? I used some tape head cleaner on it (probably isopropyl alcohol, right?) and while it's improved, it has a long way to go. I just want to be sure I don't damage the printing.
Post by kingman » Sat Jun 01, 2013 3:33 pm
Never!!!! NEVER!!! use windex or any ammonia based cleaner!!!! I would test a small spot before I even attempted to swipe something on the face.
Post by kingman » Sat Jun 01, 2013 3:34 pm
kingman wrote:Never!!!! NEVER!!! use windex or any ammonia based cleaner!!!! I would test a small spot before I even attempted to swipe something on the face. By the looks, someone has already cleaned it wrong and you are stuck with the bad result!
lipwak
Post by lipwak » Sat Jun 01, 2013 3:53 pm
That was me. It was tape head cleaner, probably from Radio Shack. I assumed it was isopropyl alcohol. I won't use Windex or anything with ammonia. Thanks.
