It is currently Mon Mar 27, 2017 11:15 pm
MXR-130 buzzing sound
cring08
Post Sun Jul 21, 2013 7:01 pm
My mxr130 is in the basement where i have the gym set up.
We bought a new treadmill, and when its on, the mxr has a loud vibration and buzz from the rear left corner.
Any ideas?
Chris
Living Room/main System:
Sunfire TGP IV
Carver Amazing Silvers
Apple tv
Carver SD 390t
Technics SL 1950 Turntable
Basement/system 2:
Carver MXR-130
Teac reel to reel
BBE 362 Sonic Maximizer
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Pioneer 100 disk changer
Garage system:
Pioneer VSX something?
Polk Audio 2500
Post Sun Jul 21, 2013 7:20 pm
Re: MXR-130 buzzing sound
Try a different outlet? :-k
Sunfire Theater Grand III
Sunfire Cinema Grand Signature 405x5
Klipsch forte II Mains
Klipsch RC-7 Center and Surrounds
Klipsch RSW-12 Sub
Post Sun Jul 21, 2013 9:05 pm
Treadmills in use are a heavy electrical load. Your steps can actually modulate the power such that you can sometimes see the footsteps in lights. Put on analog voltmeter on that circuit and you'd likely see it dragging the line down a shocking (pun intended) amount every step. They use switch mode supplies that impress a ton of trash on the power line too.
Your hearing an indication of this. I'd suggest for the health of the unit that you want to change something pronto.
It might be advisable to check the tightness of the screws on the outlet and any others in the circuit that daisy chain to the one used for the treadmill. And then the breaker at the panel should also be checked.
The noise in the transformer is indicating that the impedance there is not very low or it wouldn't be possible to impess that much noise on the line and then over into the amps transformer windings.
I was there for the 10th Carverfest! Glad you were too! Or you should have been...
cring08
Post Mon Jul 22, 2013 11:11 am
It's on a seperate outlet, but probably the same fuse.
I'll see if I can seperate them, and check everything you guys suggested.
Thanks!
Chris
Sunfire TGP IV
Apple tv
Carver SD 390t
Basement/system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Garage system:
Polk Audio 2500
Users browsing this forum: Baidu [Spider] and 4 guests
