what to expect with a 2.0v rms difference
kirstenj
Post by kirstenj » Mon Sep 02, 2013 2:16 am
I stumbled on this article (http://www.audioholics.com/audio-amplif ... ltage-gain) when looking for advice on setting the impedance on my pre-amp. I found the answer to that out elsewhere, but got curious about how my pre-amp and amp matched up. I followed the formulas and came up with the Sunfire 300x2 wanting no less than 4.8v rms, but the Yamaha RX-A1010 pre-amp delivering only 2.8 via the pre-outs. With this 2.0 difference, does this equate to only being able to drive the Sunfire 300x2 at around 58% of it's max output? The volume from this setup is more than enough in our small house, so I'm asking this purely out of curiosity and wanting to learn.
Re: what to expect with a 2.0v rms difference
Post by TNRabbit » Mon Sep 02, 2013 7:18 am
Yes, it basically means you won't realize it's full potential. Possibly a slightly higher noise floor.
Post by mbskeam » Mon Sep 02, 2013 9:41 am
if you look in the upper right corner your answer is there.
kirstenj
Post by kirstenj » Tue Sep 03, 2013 12:45 am
Thanks Gary.
Re the manual: Not sure how input sensitivity alone would answer my question as to what to expect :-k . I did reference the manual (sensitivity etc), to input into the formulas in the article.
Post by TNRabbit » Tue Sep 03, 2013 4:47 am
How did you come up with the Sunfire needing 4.8 v minimum?
The manual states it will reach it's rated power with 1.64 v input...?
Post by radioeng2 » Tue Sep 03, 2013 8:55 am
You cannot change the output impedance of the preamp line out, so I'm not sure what that was talking about.
The idea of our equipment interfacing is what is known as voltage transfer. The general idea is that as long as there is a 10:1 ratio, you're not going to appreciably change the freq response from anything at the load end. ie....anything less than 1K output impedance into anything lighter than 10K input load and you're golden. So again, just remember the 10:1 ratio for interfacing.
So the desired, for normal voltage transfer, is low output impedance and reasonably high input impedance. Technically, lets say you've got a very nice low output impedance and several devices with really high input loads. Like 50K or higher. That means you can safely do a Y splitter and not have loading effects. The warning being that you are sharing ground currents and noise.
The reason for greater voltage output capability in a preamp is so you have extra gain available for low input level sources. Greater gain though pays the penalty of increased noise floor. So reasonable extra gain is prudent.
There is no advantage I can think of to applying more voltage to the amp input than it takes to drive it to full output. With these high power amps, I can't image most can reach that level before the speaker would give it up. Ribbons are generally the most power hungry.
Well matched preamp gain and amp gain is worthy target. When you have enough gain to get a slightly low level source to the max speaker output level you'd ever want, and the preamp gain is all the way up at that point, then you've maximized signal to noise. If you're at the full output you can stand and aren't all that far up on the preamp gain, then you're thowing away resolution.
Be careful believing anything at all from that website. They are stuck in the numbers and graphs of low fi reproduction and don't know yet that there is greater fidelity available that the numbers game doesn't show. Simpifying the technical too far and you're missing out. And that's a shame.
Post by mbskeam » Tue Sep 03, 2013 3:03 pm
I bet your vol knob will be at 11:00 for loud....
and 2:00 for party timeeeee.... \:D/ \:D/
kirstenj
Post by kirstenj » Tue Sep 03, 2013 4:36 pm
I'd plugged in numbers to those formulas and came up with the numbers. New formula (10:1) is easier. My Yamaha Rx-A1010 has output impedance of 1.2k, and the Sunfire input impedance 24k, so it looks like I'm twice what I need and "am golden" ;-)
