Sunfire Cin. Grand vs. Cin. Grand Sig.
BobSmi57
Post by BobSmi57 » Sat Apr 05, 2014 10:57 am
Hi guys. I'm new here. I would like to know if there is a difference in internal parts and sound quality between these two amps, other than the obvious doubling of power. I'm using a std. Cinema Grand to power my ALiii's and am thinking about upgrading to the Sig. Model(5x405). Thanks for your help.
Re: Sunfire Cin. Grand vs. Cin. Grand Sig.
Post by TNRabbit » Tue Apr 08, 2014 5:57 pm
The main difference is the Sig model has more output devices. Probably upgraded caps & power supply as well.
BobSmi57
Post by BobSmi57 » Tue Apr 08, 2014 7:06 pm
TNRabbit wrote:The main difference is the Sig model has more output devices. Probably upgraded caps & power supply as well.
Thanks for the info.
Bob
Post by thuffman03 » Wed Apr 09, 2014 7:55 am
The difference between the two amps is really just power. I have owned both and the Cinema Grand and the Cinema Grand Signature and both have the same sound, but the Signature is double the power. Cinema Gran is 200 wpc while the Signature is at least 400 wpc into 8 ohms.
IMO, both are good amps and will power your speakers fine. You most likely not hear any difference and the volume level between them will be pretty close but you will not be taxing the Signature as much when you play it loud as it has more power in reserve.
Now I prefer the Sunfire 600 on ALIII's. I like the sound better. I think it is voiced differently for stereo and not for home theater. Just my opinion.
wrstps
Post by wrstps » Wed Apr 09, 2014 8:22 am
Hey Bob where in SW Mi do you live I'm in the down river area
Ray
BobSmi57
Post by BobSmi57 » Wed Apr 09, 2014 7:19 pm
thuffman03 wrote:The difference between the two amps is really just power. I have owned both and the Cinema Grand and the Cinema Grand Signature and both have the same sound, but the Signature is double the power. Cinema Gran is 200 wpc while the Signature is at least 400 wpc into 8 ohms.
I appreciate your opinion , since you owned both amps. You say they have the same sound, but the Sunfire 600 sounds better to you. Does the 600 stereo amp have the same sound as the 300 stereo amp? The 600x2 is really hard to find in good condition. Maybe I could bi-amp using 2 channels of the Cinema Grand for the bass, and use a 300x2 for the ribbons.
Post by BrianT » Wed Apr 09, 2014 7:27 pm
BobSmi57 wrote: I appreciate your opinion , since you owned both amps. You say they have the same sound, but the Sunfire 600 sounds better to you. Does the 600 stereo amp have the same sound as the 300 stereo amp? The 600x2 is really hard to find in good condition. Maybe I could bi-amp using 2 channels of the Cinema Grand for the bass, and use a 300x2 for the ribbons.
Having owned a 300x2 (series 1), and now a 625x2 (series 2). For some reason I do believe that the 625x2 does sound better
EVEN at lower volumes.
I think that the mids are smother in the 625x2 than the 300x2.
Aurender N100H Music Server
Audioquest Diamond USB cable
BobSmi57
Post by BobSmi57 » Wed Apr 09, 2014 7:31 pm
wrstps wrote:Hey Bob where in SW Mi do you live I'm in the down river area
Ray
I'm on the West side of the state, near St. Joseph.
BobSmi57
Post by BobSmi57 » Wed Apr 09, 2014 7:39 pm
Thanks, Brian. Maybe I'll just keep looking for the 600x2. I know Kingman likes his, too.
Bob
Post by kingman » Wed Apr 09, 2014 7:41 pm
That would be correct....
Post by BrianT » Thu Apr 10, 2014 4:45 pm
Bob
Check your PM
trav0810
Post by trav0810 » Thu Apr 10, 2014 5:01 pm
I've owned a lot of Carver gear, but not any of the Sunfire. The 600x2 has always been a DREAM of mine. But that will probably be a long way down the road. First on my list is the Sunfire Tube Pre
Post by jjptkd » Thu Apr 10, 2014 6:38 pm
I find that the Signatures seem to have a bit more pronounced and forward midrange over the non signature models, more so with the stereo amplifiers. If money were no object I would prefer a Signature amp. The Cinema Grands are very close in sound so unless you need more power anyway it would be hard to justify the additional cost in my opinion.
Oppo Sonica DAC
Sunfire TG-III
Klipsch Chorus II
Post by angelod307 » Fri Apr 11, 2014 12:27 am
I agree. The same, but not the same in five versus two channel sunfire.
Post by angelod307 » Fri Apr 11, 2014 12:28 am
No the six hundred is not as laid back as the three hundred.
