What are the specs for this receiver?
G_Loc
Post by G_Loc » Sun Apr 04, 2004 11:24 pm
This receiver was given to me at work a few days ago and I havne't been able to find any specs for it. There's no model number or anything on it...
thanks for any help
mikeg
Post by mikeg » Mon Apr 05, 2004 12:26 am
I believe the receiver in question is the aptly named THE CARVER RECEIVER. The specifications for the unit are given below.
Power: 150W/channel in 8 ohms with < .05% THD
Slew factor: > 80
Freq response: 1Hz - 30Khz +/- 1db
Protection: Short circuit, DC offset, low/high frequency trip
FM Tuner
S/N: 76db
distortion: .2%
freq response: 20 - 15Khz +/- 1db
stereo seperation: 42db
capture ratio: 1.5db
Noise reduction: 7db
Multipath reduction: 13db
PREAMP
Distortion: .05%
S/N: 90db
Freq Response: 20hz - 20Khz +/- .5db
Good luck
G_Loc
Post by G_Loc » Mon Apr 05, 2004 9:22 am
Cool cool....
You think I can use it to power a 12" DVC subwoofer with coils rated at 4 ohms each?
mikeg
Post by mikeg » Mon Apr 05, 2004 1:11 pm
You should be able to drive the 4 ohm load, power should be around 200- 220 W/channel max.
George
Post by George » Mon Apr 05, 2004 7:15 pm
Might be the 130wpc version , which was the original "Carver Receiver". The 150wpc (157 actually) version was sometimes called "The Receiver 150".
It'll do 4 ohms just fine. You have some fine co-workers.
