It is currently Wed Jun 19, 2013 2:47 pm
M500T
reactor
Post Sun May 02, 2004 10:28 am
M500T
Can the Carver M500T be bridged into 4ohms?? I have a sub I want to power up but I am not sure if my amp will do 4ohms.....
George
Post Sun May 02, 2004 12:13 pm
Once you decide to use the amp in bridged mode, you're better off sticking to 8 ohm loads.
reactor
Post Sun May 02, 2004 2:03 pm
Really?? So I guess I better wait until i get a proper amp..
Thanks
AH
reactor
Post Mon May 03, 2004 6:39 pm
George? M500 Owners
If I hook the sub up to , say the left side, will the amp be working at a 4ohm load..I read somewhere that the M500T will run at 500 watts per channel at 4 ohms...
Thanks
AH
George
Post Tue May 04, 2004 9:16 pm
If you're talking about using only one channel while in stereo mode to drive a 4 ohm sub, I don't see a problem with that. Only a problem driving 4 ohm loads when in bridged mode.
I'm not sure that problem is relegated to Carver amps only.
Post Wed May 05, 2004 12:07 am
No, it's not only Carver amps. I could be wrong on this, but I believe it applies to all bridged amps.
