Why not use PM series in the home??
Thanks,
It is currently Sun May 26, 2013 3:38 am
(Pair of Silver 9t's)
maddmaxxx wrote:-but AVRizers look kuul on any amp
-do the pm amps have vents on the bottom ?
-i've been using 4"computer fans since aprox '95..they are real quite and i recomend them
-can barely hear the fans[2], when changing discs or source
-the tfm/75 has a fan too
bob p wrote:the PM amps are indeed more robust than their consumer grade counterparts. i use a pair of PM-1.5 to biamp my main listening rig. (they're swapped out right now for a monoamped M-500t that i've been "testing" for the past month after bringing it back from the dead.)
i replaced the original fans on the PM-1.5 with new OEM replacements, as the 20+ year old fans had noisy bearings. the new fan's have nice quiet bearings. i tweaked the fan control circuits to adjust the fan speeds so that they're quiet enough for home use, but speed up appropriately to augment cooling when the amps operate under load.
i can't see any reason not to use them. the only problem is that being racked devices, they have no feet, so you'll need to use stick-on bumpers to keep them from scratching one anther if you stack them instead of racking them. AV-Rizers aren't ?needed because the fans pull air from back to front instead of using passive cooling from bottom to top.
bob p wrote:the PM-1.5 has the same basic chassis as the M-1.5t, so yes it has some vent holes on the bottom, because you have to remove an access panel to get to the power transistor sockets. But those vent holes are non-functional for the most part, as the cover for the amp is SOLID. There are NO ventilation holes on the top or sides of the PM amp like there are on the M amp. ALL of the air is drawn by the fan from back-to-front, which is the norm in rack mounted gear. Cool air in through the back of the rack, hot air out of the front.
treitz3 wrote:Blast from the past thread of the day....
Well, this year we will have a TFM-75 and it's PM series counterpart at Carverfest. We will all be able to make observations and you can answer the question for yourself, engtaz.
Let the battle begin!
