Plus 350 wpc (one M-500t running into 4-ohm Martin Logan Scenarios) for the rears.
Plus another 350 watts (one channel of another M-500t running a 4 ohm Martn Logan Logos) for the center.
And I'm also running a Velodyne F-1500B sub with an on-board 250w amp.
Total potential power output at clipping: 3100 watts
Every single watt of which is glorious Carver Solid State...
(except for the sub...)
But in all honesty, I never run my rig at anything much more than about 15% of it's potential output. If I did, I'd suffer permanent hearning loss within a matter of a few hours...
--Richard
• 2 Ch. Rig • Carver C-4000t • Silver 7t's • Krell KAV-300i • Oppo DV-981HD • Benchmark DAC1-USB • MacBook Pro 17", iTunes •
). But they are very smooth sounding so I can push my TFM-35's capability and get them to use the full 250 w/c; easier to do with classical or of course drum music like "Time" by Chamber Brothers, e.g.). But I agree, 90% of the time 15 w/c would be fine (with some headroom for the occasional transient...of course
). And I'm also very glad that I added a toggle switch to them so that I can toggle them between the four woofers all in // (with a 1 ohm 25 w resistor to boost the d.c. resistance up to about 3 ohm) to two groups in // in series (no resistor needed for about 7 ohm d.c. resistance). Kind of depends on what "mood" I'm in which sounds better: all four in // mode (how the later SN 1000's were wired) has maybe better, fuller bass (due to lower overall resistance thru the woofer leg in this mode vs tweeter leg of the circut), whereas the two groups of 2 in // in series (how the early SN 1000's were wired) has perhaps better "detail" and "brighter" tweeters due to opposite effect (more d.c. resistance thru the woofer leg of the circut relative to tweeter leg). aside: Both modes improved when I did an alignment recently of my TFM-35.... Of course the effects of either mode are subtle and end user subjective, but I very much like this flexibility built into "my" 1000's (anyone who wants the schematic for wiring in this 3PDT toogle switch (perhaps applicable to any set of speakers with four woofers; but probably not!), let me know; I have it in a Word doc format.
