Re: How many watts per channel do you run with?
Toy Maker wrote:I know I'm running BELOW 2-Ohms.... 1.8 static... probably down to 1 or less at decent volume.
It is currently Thu May 23, 2013 7:34 am
bruce.weiland@verizon.net wrote:......When I add each individual 200 W subwoofer amp to the two Moscode's, I think I still come up with 2.4 kilowatts.......
Dr. W wrote:.........George said the amp would deliver 55 volts at 20 Hz. Now I am not entirely sure what that means. The amps have 90 volt rails.
Dr. W wrote:...... When bridged the speaker would "see" 110 volts at 20 Hz because the speaker terminals are not connected to ground but rather the two positive terminals.
It is often heard said that bridging gives one four times the output (assuming no power supply sag or limit). An EE friend of mine pointed out that that is somewhat just semantics.
Dr. W wrote:.....Bridging, as it is generally done and my friend calls "series" bridging, does not give one four times the output of the stereo amp......When we hook up an 8 ohm speaker to the bridged mono amp it is effectively seeing a 4 ohm load and therefore a bridged 50w/channel stereo amp can deliver no more power than the stereo amp unbridge.....
Dr. W wrote:..........You know that the rails are 90 volts, the MOSFET output devices are QN113 (8310) or K176 (Japan B1), I think Toshiba. There are 6 devices per channel, theoretically how much current can these devices deliver?
can't find datasheets for these devices, but if the designer said it'll sustain 55V that's 378W into 8R. By way of comparison the M-1.0t i'm playing with will do 400W into 8R (56V) so it's rms is close.
With dynamic 20ms pulses it'll do 928W into 2R, and as long as the PS can provide the current, those MOSFET devices should handle at least that much dissipation
Dr. W wrote:.....Since, I believe, there is very little content in the 20kHz range and my speaker approach 2 ohms as high frequency reproduction goes up to 20kHz, the amp would be seldom asked to drive such a low resistive load (I understand that resistance and impedance are not the same, but not why).
Dr. W wrote:.....That being the case, very little content up where the speaker impedance is very low, why do many amps have such a time with electrostats? Is it the capcitive load they present or a combination of that and the low impedance at higher frequencies?.....
Dr. W wrote:...Would a theoretic amp or my amp or any amp deliver a different voltage at half the load, just as it would flow more current (within its design limits) at a lower resistive load?....
