It is currently Tue Jun 18, 2013 1:52 am
m400 fuses
m400
Post Thu Dec 18, 2003 12:53 am
m400 fuses
I posted this under the repair forum as well.
I have an M400 amp which blew it's fuse. It takes a 15 amp 32 volt fuse and the back of the amp says Line Fuse AGC 15.
Found a fuse put it in and it blew as well. It is an automotive fuse though, should it work?
Any help would be appreciated.
Thanks,
waveform
Post Fri Feb 20, 2004 11:09 pm
Your fuse is blowing because...
It has to be a SLOW BLOW type fuse! I went through this headache once with my M-500t back in the 80's. My 10 amp fuse had a white paper like cylinder for the body, the one you need may look different, I dunno. But I DO know that a regular fuse will blow almost immediately, LMAO...
fuggetaboutit...
