Sub question?
http://cgi.ebay.com/Sunfire-True-Subwoo ... 2ea83553cd
It is currently Sun May 26, 2013 3:38 am
Jag_97470 wrote:A Sunfire Sub Junior on e-bay. I'm not interested in a sub right now but thinking about connections? The last speaker set-up I had was Infinity Satellites with 2-10" subs that I have now given to my daughter. When I did have these hooked up, I wired in series with the satellites. If you were to hook up say 2 of these Junior's would you wire the same? or run the sub output from the TGP-III direct to the subs and use the internal amp in the sub? I guess there is different ways to wire a sub, just not sure what is the best? Thanks
