It is currently Tue Jun 18, 2013 2:45 am
Power rating of Carver AV-705x in 4 ohms.
• Page 1 of 1
Got a used Carver AV-705x without manual. I would like to know the power rating of this amp in 4 ohms. Anyone who knows? Thanks in advance.
same exact issue!
I just bought one couple days ago off ebay and I cant find 4 ohm specs either! I have 4 ohm speakers I want to hook it up to and I sure hope it can handle it....phhhhhh
(Pair of Silver 9t's)
I know this thread is a few months old but I do have a manual for the AV-705x. Always keep my manuals for future reference or if I sell the product so I can pass it along to the new owner. It doesn't have a rating for 4 ohms, but I'll give you the spec's that are in the manual.
_____________________________________________________________
AV-705x Specifications directly from the User Manual.
Stereo Power: 180w/ch from 20Hz to 20kHz w/no more than 0.08% THD.
All channels driven: 125w/ch into 8 ohms from 20Hz to 20kHz w/no more than 0.08% THD.
Power Steering Capability: >200 watts into 8 ohms
Dynamic Headroom: 1.1 dB @ 8 ohms(all channels driven)
Frequency Response: 20Hz to 20kHz (+0, -0.2 dB)
Separation: >70 dB (@1kHz)
Damping Factor: >300 20Hz to 20kHz
Imput Impedance: 50K ohms in parallel with 120 pF
Sensitivity: Per THX standard: 1.0V rms input for 100W output into 8 ohms (with input Sensitivity controls fully clockwise)
Gain: 29.0 dB (+/- 0.5dB)
Distortion: IM <0.01% CCIF
<0.03% SMPTE
THD <0>114 dB A-weighted, referenced to rated power
>93 dB A-weighted, referenced to 1W into 8 ohms.
Power Consumption: 100W at idle
600W with musical program
1100W at full power into 8 ohms.
Dimensions: 5.75" x 19" x 18.7" (including handles & feet)
Net Weight: 42.0 lbs
Shipping Weight: 47.0 lbs
Made in Woodinville, WA
I also have a Carver Brochure that has spec's for the following Carver products, if anyone is interested.
AV-753x, AV-505, A-760x, A-500x, A-220, A-140, HTR-885.1, CM-2002, CT-25.1, CT-24v, MV-5, DD-5.1, Cinema 5.4x, Cinema 5.2, & Cinema 5.1.
<0.03% SMPTE
Helping future owners out.......cool deal.
Thanks LCSeminole for posting that information [for the good of the forum].
• Page 1 of 1
