It is currently Sun May 26, 2013 3:52 am
M1.ot amp quest.?
Magoo
Post Fri Jan 18, 2013 12:35 pm
M1.ot amp quest.?
Hi guys,
I am thinking about buying another M1.o amp. My ques is, If I bridge them can I still drive less than a 8 ohm load or not? It says 1000 watts into 8, but my speakers are 6 ohm.
Thanks for any help
Post Fri Jan 18, 2013 2:15 pm
Re: M1.ot amp quest.?
Depends on HOW HARD you intend to drive them. What speakers? What is your usual listening volume?
It's not GENERALLY recommended, but it does depend on circumstances. If the speakers are bi-amp ready, that would probably be a better way to go.
Magoo
Post Fri Jan 18, 2013 8:59 pm
I now have Klipsch RF35 floor standing, but am looking at possibly some Martin Logan Aerious's.
Just wasn't sure? Thank you!
Post Sat Jan 19, 2013 12:00 am
You would MELT the RF-35s with a pair of bridged M-1.0t's, good possibility still with a single amp in stereo. The M-1.0t is a VERY under-rated amplifier. 200 watts per channel with 3db headroom ='s a 400 watt amp. A single M-1.0t will easily drive the Klipsch's, not sure about the Logan's though.
Post Sat Jan 19, 2013 12:28 am
DEFINITELY bi-amp the MLs!!
Magic_Physicist
Post Sat Jan 19, 2013 6:50 am
I destroyed several ALS crossovers with mine in the past :lol:
