It is currently Sun Jun 25, 2017 2:14 am
av806x
kawika
Post Fri Sep 20, 2013 1:52 pm
av806x
does any one know how to connect the av-806x to a yamaha rx-v767 receiver? I trying use the pre-out input on the rx-v767 to connect from the av-806x amp. Can anyone show or tell me where the R/L front, and R/L rear speakers wires goes into on the pre-out input pof the yamaha receiver??
Post Fri Sep 20, 2013 7:47 pm
Re: av806x
The section labeled "Pre out" is were you need to hook to, bottom right inputs highlighted in white if you're looking at the rear of the unit.
ddbroderick
Post Tue Sep 24, 2013 6:54 am
Re: av806x
Welcome to the forum.
You need to run RCA cables to connect the two. From the Yamaha connect the Front Left to Front Left or channel 1 on the Carver. Repeat for each channel so that all channels are connected (one at a time using RCA cables).
Run speaker wires from the Carver ONLY to your speakers. Turn on both and enjoy.
