av806x
kawika
av806x
Post by kawika » Fri Sep 20, 2013 1:52 pm
does any one know how to connect the av-806x to a yamaha rx-v767 receiver? I trying use the pre-out input on the rx-v767 to connect from the av-806x amp. Can anyone show or tell me where the R/L front, and R/L rear speakers wires goes into on the pre-out input pof the yamaha receiver??
Re: av806x
Post by jjptkd » Fri Sep 20, 2013 7:47 pm
The section labeled "Pre out" is were you need to hook to, bottom right inputs highlighted in white if you're looking at the rear of the unit.
ddbroderick
Re: av806x
Post by ddbroderick » Tue Sep 24, 2013 6:54 am
Welcome to the forum.
You need to run RCA cables to connect the two. From the Yamaha connect the Front Left to Front Left or channel 1 on the Carver. Repeat for each channel so that all channels are connected (one at a time using RCA cables).
Run speaker wires from the Carver ONLY to your speakers. Turn on both and enjoy.
