It is currently Tue Jun 18, 2013 6:52 pm
Sunfire Theater Grand V Vs C1 preamp
Re: Sunfire Theater Grand V Vs C1 preamp
No comment other than that as I have not heard them head to head. Rock on bro'!
Short answer, go where the best DACs are. If they are in your source, go with an analog pre, otherwise go with a digital pre.
BTW, I'd pick up a used TGP III or IV rather than a TGP-V. You can save some bucks, and at least I know that the III was made in the USA.
EDIT: The TGP's also have 8 channel analog input (I use that for SACD using the DACs in the Oppo),
BillD wrote:I have a C-4000 modified to be a lot better than stock...
Bill, could you PM me as to the details of this mod? Did you do it yourself, or did someone mod it for you? My C-4000t is in pretty good shape, but it's starting to get a little noisy sometimes, and the stock SH is, as I'm sure you know, perhaps the most noisy circuit ever put in a Carver product. I'd like to keep thsi classic preamp in service, and your modded unit sounds like just what I've always dreamed the C-4000t SHOULD have sounded like.
--Richard
• 2 Ch. Rig • Carver C-4000t • Silver 7t's • Krell KAV-300i • Oppo DV-981HD • Benchmark DAC1-USB • MacBook Pro 17", iTunes •
. I really hope the TG-5 sounds better but I'll have to reserve jugement. One thing I will tell you if it's no better I will say so even though these processors cost ten times more than those C1's. I'm not goung to kick it out of the system just yet. I've always had the amazings and Silver 9t's so I can't really say how it would work with other gear. Art
The TGP-V does HDMI video switching, but it DOES NOT carry digital audio over it's HDMI ports from what I understand, so you still need to connect any HDMI device to it with a TOSLINK or coax for sound, right?
I dodn't realise it had digital bass management. How does it stack up against the Velodyne SMS-1? Does anyone out there with a TGP-4 or 5 also have an SMS-1? How to they compare?
Also, does anyone with one of the Sunfire preamps also have a Benchmark DAC? How do the on-board DACs in the Sunfire pre's stack up against the Benchmark for 2-channel? I know they beat the Benchmark for multi-channel (the Benchmark is only 2-channel), but I'm curious how the Sunfires do as far as stereo DACs.
--Richard
I will say that in processor bypass mode ("sound direct") the Sunfire is DEAD SILENT and I don't think you can beat it. Unfortunately, you can't engage Sonic Holography in this mode.
From everything I've heard about Sunfire' how can Carver even compare ?
Mr. M-500t wrote:I can't believe this has gone as far as it has !
Get thee a Lightstar.
