tah800 wrote:O.K. after reading all this old Mr Dumbass here is getting more confused by the minute. So from all of this 1.I should hook my Bluray player directly to the T.V. with an HDMI cable. 2. Should I then hook a piece of digital cable(by the way is digital coax and digital cable the same thing) to my DVD player and then to the TG-5. So I have sound runnning through both cables?????? .
Bingo.
The ONLY advantage to running your HDMI through a pre/pro or receiver THEN a single cable to the TV is that it makes switching sources a little simpler. If SAF (spouse approval Factor) is your top priority, this is the way to go. Bu tif you're striving for teh best performance from you rrig in both audio and video, you need to keep the signal chains as short as possible. Run video from sources DIRECTLY to the TV, via HDMI. Run digital audio from sources to the preamp via digial links.
Although it makes switching sources a little more involved, here is the one BIG advantage to doing it this way" you don't HAVE to listen to sound through the stereo all the time. If you want to just watch CNN, or an excercise DVD or somethign where sound isn't all that critical, by running your sources directly to the TV AND to the preamp, you have the option to JUSt use the built-in TV speakers. Whe you DO want the whole "home theater" experience, put your TV on "mute", and crank up the preamp...
tah800 wrote:Now with my CD player should I run a piece of digital cable from it to the TG-5 or just use a set of high quality RCA's. I have The Rotel RCD1072. Someone told me the Digital Audio Converters on both the CD player and the processor should be of equally high quality. I would have no idea. A lot of peole told me that the processor would just act as a switching station. I don't know what you mean there either.
By "switching station", we mean that if you have multiple video sources (for instance, a VCR, DVD player, and cable box), you COULD run them ALL into the preamp, then just run a single HDMI to the TV. Then, when you want to change sources, you just chose the correct input on the preamp, and the correct sound comes out of the speakers, and the corresponding video gets sent to the TV. This kind of setup will make your family much happier, because it's dead simple. However, you do get some compromise in video quality...
OR you do it like I said, running HDMIs from sources to the TV, and then passing the digial audio to the preamp from sources via some sort of digital cable. This makes changing sources a little more complicated--you have to choose the "input" on your TV's menu, AND choose the correct source on the preamp to get the sound to come out of your surround sound system. Bu toveral performance will be better, because you've removed a VERY complicated, processing-heavy bit of gear out of the video signal chain.
See what I mean now?
Home Theater systems are a WHOLE different ball of wax than a 2-channel stereo. It's not just "the next step" in a home system--the level of technological escalation and complication is like the difference between a 1969 VW Beetle and a Koenigseg. The audio/video business really makes it sound overly simple, and the fact is that if you're used to setting up an "old school" 2-channel rig, a 5.1 home theater system is a MASSIVE leap in terms of complexity. Not only are you adding a whole extra layer of signals--video--but you;ve also got a subwoofer, a center speaker and 2 rears that you need to get all dialed in and properly calibrated for it to sound worth a damn. Luckily, most good HT preamps and receivers have "auto-calibration" features and come with a calibration mic. In MOST systems, for the average user, this is good enough, but most of us tweekers and geeks just use this setting as a "starting point". I NEVER settle for the audo-cal settings on my HT system. I always adjust the sub (usually dial it WAY down from the auto setting), the center (usually turn it up a tiny bit) and the rears (usually turn them up several notches). But then again, I'm a geek and a tweeker--I have an SPL meter and I'm not afraid to use it...
As for your CD player, I'd say try both the analog outputs and the digital. If you like the DACs in your Rotel player better, stock with them. You may find that the Sunfire has slightly more "detailed" sound though--it does have VERY good onboard DACs, and can outperform most non-audiophile-level CD players. However, some folks find the Sunfire DAC to be a little on the "edgy" side, especially if you are used to a really "laid back" sound like from some of the "British" gear like Meridian, Cambridge, or Rega. The Rotel CD players have always sounded very "clean" to me--a little more forward tha "Brit gear" but not quite as "agressive" or "clinical" as some of the Japanese or American "high-end" stuff like Krell, Esoteric, Marantz, or Sony ES...
I'd say try both--let your ears decide which way sounds better in your rig...
tah800 wrote:So listen don't dazzle me to death with to much info Let's just stick to the ideas here and remember let's use the old K.I.S.S mentality. Your dealing with a guy whose only had a set of Carvers, a set of Silver T blocks ,an old C1. 2 pairs of RCA cables and a set of speaker cables and I was good to go. SACD's ,Toslink I don't know a thing about them.Art P.S. Yeah yeah I know not the sharpest tool in the shed right???
SACD is a higher-resolution format for audio CDs. Some SACDs are just 2-channel (but they sound WAY better than regular CDs) and some have 5.1 surround information. The difference between SACD and regular CDs in terms of clarity, detail and "realness" is akin to the difference between regular DVDs and BluRay discs...
TOSLINK is a digital interface developed by Toshiba with the original purpose of passing "control" signals between components, like "synch" signals for dubbing from CD to cassette, or "triggers" for turning a stack of gear on and off, or for controlling a stack of gear through a receiver using just one remote. They decided sometime in the early 1990s that they could pass a digital audio signal over TOSLINK, and started pushing it as a marketing ploy. The fact is, if you have another option for passing a digital signal (like coax or HDMI), you should use it--TOSLINK is generally considered a digital cable of last resort in the "audiophile" world. TOSLINK is also know as "Optical" or "Fiber Optic", and used plastic fiber optic cable to pass a pulsed light signal (in most cases, it's a red laser).
When I say "Digital Coax" I'm talking about the single RCA jacks on the back of your components (usually they have an orange color coded insulator) that are usually marked just "Digital". This uses a cable that looks pretty much exactly like the cables you're used to working with--they have an RCA plug on each end, and use standard wire as the conductor. No fancy-schmancy lasers or fiber optic cable or other 21st century techno-magic here--just good old fashioned electrical signals passing through a wire. Many folks think that if you're going to pass a digital signal from a component to an outboard DAC or to a preamp/receiver, this is the way to go. I tend to agree. I have always found (in my rig) that digital coax just sounds more detailed and "natural" than TOSLINK. To me, TOSLINK connections sound grainy, veiled, and a little muffled.
The only time I use TOSLINK is when I don't have any other choice. I use it to connect my Airport Express to the receiver (for wirelessly streaming music from my laptop from iTunes into the stereo), and for connecting my Cable box to the system (because if I use a "wire" connector for the audio from my cable box, I get TERRIBLE ground loop hum. The one and ONLY advantage to TOSLINK is that it does isolate the connected components electrically, so it can help fix ground-loop hum issues that are caused by the bizarre grounding schemes used by many cable systems.)
I know this is a LOT of information. But you gotta understand--a HT (home theater) system is a TREMENDOUS leap up in terms of technology, compared to a 2-channel, music-only rig. You're adding video, multi-channel audio, surround processing, all sorts of technological mojo. It's not just a few steps up, its like the express elevator to the penthouse...
Keep asking questions. We'll keep trying to answer them. We're geeky that way...
--Richard
