In case you haven't seen it...
If you could get the ribbon up above the woof box I would think that would be an improvement. I wonder if stock ALIII x-over was utilized.
Pretty cool though.
It is currently Mon May 20, 2013 1:28 am
Dreamer wrote:The only problem with that design, is the dispersion pattern from a ribbon turned sideawyas must be VERY beamy, inthe vertical plane. I bet it has a huge, wide sweet and juicy like these nutz. spot, but it's probably in a vertical plane of about 1 foot. I mean, we all know how beamy the ribbons can be in a normal configuration, now just rotate that 90 degrees...
BillD wrote:Looks like a goddamn coffin. Bet that gets some strange looks sitting in a living room. Great idea though. I think making a center with the smaller ribbons like in the CRM or CRS series from Sunfire makes a little more sense for me (sorry Jean).
No worries at all... I like what we did but I am sure it can be improved....the sub is on the floor 5 feet from it pointed towards the centre -just like to have fun with audio...use what you have and try and make it work, its all good
HMMMMM maybe we could bend the damn ribbon....teehee hee that would be cool...start working on it toymaker!!!!
