DPL33 and CT17
Thanks,
Keith A.
Keith A, Carver audio guy from Canada
It is currently Fri May 24, 2013 7:16 am
Jag_97470 wrote:You the Man OBI56! oh wait, what did you call me? Let me rephrase that; You the Silly Ol Goat!! LOL!
Yes I know, not much gets by me.
OBI56 wrote:Keith, your situation comes about because ofa duplication of certain parts of your system. The CT-17 is a Preamp / tuner / Dolby Processor. The DPL-33 is a Dolby Processor / low power 3 channel power amplifier. Both of these are integrated units that do not allow each section or function to be used as a separate component (with the exception of the DPL-33's Dolby processor which can be used on its own with an external 3 channel amplifier).
In your present setup, you are not using the CT-17's Dolby Processor; routing that function to your DPL-33. If you want ot use the CT-17'S internal Dolby Processor, you will have to set the DPL-33 aside and get an external 3 channel amp.
On a side note, the wiring diagrams in the DPL-33 manual take into account that you have a cassette tape deck in the mix. If this is not your case, there is a much simpler wiring setup available which does not use a tape loop which I can draw up for you if you want.
KeithA0000 wrote:OBI56 wrote:Keith, your situation comes about because ofa duplication of certain parts of your system. The CT-17 is a Preamp / tuner / Dolby Processor. The DPL-33 is a Dolby Processor / low power 3 channel power amplifier. Both of these are integrated units that do not allow each section or function to be used as a separate component (with the exception of the DPL-33's Dolby processor which can be used on its own with an external 3 channel amplifier).
Thank you for your reply OBI56.
My current setup, with the DPL-33, I get 5.1: L&R driven by the ct17, and two surrounds, a center and a subwoofer from the dpl33. Would I be able to get all that from just the ct17?
Regarding the simplified wiring, I'd be interested in a simplified configuration, if you have the time.
Regards,
Keith A.
