Post by Zoot Horn » Mon Jun 14, 2010 5:33 pm
not to mention painful :shock:
edriz
Post by edriz » Mon Jun 14, 2010 6:20 pm
Zoot Horn wrote:not to mention painful :shock:
Yeah....wouldn't it be nice \:D/
Currently In Use
Current Rack; Carver M-4.0t Power Amp, Carver C-4000t Pre Amp,Empire 598III Turntable, Denon DL-103R cart/stylus,Pioneer RT-909 Reel To Reel,Nakamichi Dragon cassette deck,DBX Pro Series 231 Dual Channel 31 band EQ,Pioneer PDR-555RW CD,DBX-3bx,Berwun Research 7000A TNE,DBX-224x DS TypeII NR, Klipsch Lascalas "Loud,Proud,Clean & Mean"
rush
Post by rush » Tue Sep 18, 2012 9:55 pm
Well i am in the midst of reading this section(watts per channel)..I have a question here. running a ct-7 with m1.5t into a pair of belle klipsch. how dow I know at what point (what is the the wattage is being pumped )? with this particular amp when the lights just start to flicker is that a possible tell sign? thanks in advance, "listening" to all these discussions is getting my gears turning...
Post by elgrau » Wed Sep 19, 2012 2:49 pm
Hey Rush, I THINK the thread is just asking what is the peak (into 8 ohms most likely) rms output wattage per channel of the main power amp that you use for your main system....
Post by beemers417 » Wed Sep 19, 2012 6:42 pm
This is a trick question.
Post by kingman » Wed Sep 19, 2012 7:25 pm
More than enough.....
Post by OconeeOrange » Wed Sep 19, 2012 7:44 pm
beemers417 wrote:This is a trick question.
It is a trick question.
An amp to make you happy is:
- well, these days many are playing with tubes.
- as to SS, Carver guys are always upgrading when we can even if it is not needed or only our heart can hear the difference.
- if you are not a collector or a hobby guy, it is amazing how little you need to put out sound that will amaze all but the real audio crowd who might actually need to look and not just hear - :rolleyes: :rolleyes:
Invest some time, not just money and all things are possible.
AUDIO IS NOT JUST ABOUT THE EARS - SORRY KM. It should be, but it is not. :-({|=
AlexSauter
Site Admin
Post by AlexSauter » Thu Sep 20, 2012 11:54 am
Hehehehehehe!!!!
At the moment we (toy maker and i) are pounding my Modded AL III's with a single lightstar, but hopefully soon, i will be able to pull my PT1800 out and biamp the ALIII's with tue PT2400 that im getting from Eric!! ^_^ cant wait to dump 1500 wpc into these babies!!!!
(Stereo System)
Carver Pro PT-1800
Logitech Squeezebox
Post by angelod307 » Thu Sep 20, 2012 12:44 pm
i have more watts than sence.
Post by radioeng2 » Thu Sep 20, 2012 1:08 pm
AlexSauter wrote:Hehehehehehe!!!!
Be careful....You'll shoot your eye out!!!
austinstephens
Post by austinstephens » Thu Sep 20, 2012 1:16 pm
Two restored PM 1.5 monoblocks..Around 1200 each into 4 ohms...Carver Original ALS...These amps makes them dance. Will post pics soon...
"Despite all the amputations, she could dance to a rock and roll station, and it was all right"....Lou Reed
Post by TNRabbit » Thu Sep 20, 2012 3:52 pm
rush wrote:Well i am in the midst of reading this section(watts per channel)..I have a question here. running a ct-7 with m1.5t into a pair of belle klipsch. how dow I know at what point (what is the the wattage is being pumped )? with this particular amp when the lights just start to flicker is that a possible tell sign? thanks in advance, "listening" to all these discussions is getting my gears turning...
I believe the manual has an approximation of output into 8 ohms at each LED level. I don't know off the top of my head, but surely someone here has a manual....
AudioJack
Post by AudioJack » Thu Sep 20, 2012 4:01 pm
My L and R Mains 600 watts 8 ohms each
My Center, and L and R rear Surrounds 200 watts 8 ohms each
Jack
Sunfire TGP-5, Sunfire Signature 600 ~ Two, Sunfire True Sub Signature.
Oppo BDP-83SE Argentum Mythos; Wadia 170i Argentum Argento; Acarian Alon IVs (2 ch)
Paradigm CC590 Center + (2) Gallo Strada Surrounds with Emotiva XPA 3 ch amp.
Post by engtaz » Thu Sep 20, 2012 4:52 pm
750 X 2
Martin1970
Post by Martin1970 » Thu Sep 20, 2012 6:20 pm
Work in progress.
400x7 amplifier, all channels used.
L+R sent to subwoofers using one channel.
7 channels of 2 point 0 labels.JPG (50.41 KiB) Viewed 3097 times
2800 per stereo channel available?
Whether or not it can actually do that is anyone's guess.
Lights dim and (amazing) woofers smoke occasionally.
The joule meter needle never budges.
And I've got nothing on crazyass Angelo who biamps with two 600x2s!
If 2-way is biamping
and 3-way is triamping,
what the hell is 4-way?
