It is currently Wed Jun 19, 2013 7:54 pm
Ribbon buzzing
Post Tue May 18, 2010 11:20 pm
Re: Ribbon buzzing
Asoundpainter
Post Wed May 19, 2010 8:18 am
Re: Ribbon buzzing
The one thats got those two japanese bee's. I believe episode 29 or somewhere thereabouts!
Post Fri May 21, 2010 3:21 pm
Re: Ribbon buzzing
I could be wrong but did I read somewhere about using hairspray or something of the sort. I think part of the ribbon is slightly loose and I mean slightly. Just enough to hear it.
marantzfan
Post Tue Jun 29, 2010 1:16 am
Re: Ribbon buzzing
I just acquired some ALIII ribbons to replace the damaged ribbon in my Amazing Silvers. I figured best to keep the matched type together then have one ALIII ribbon and one Silver ribbon.
Anyhow, I have the buzz. I am quite certain that it didn't exist before these were shipped to me and I wonder it climate difference from there to here can be partially to blame?? I live in a desert (Phoenix AZ) and these came from the Midwest. I have been a little gun shy to start tightening up screws for fear of damaging these. It seems as though both ribbons are buzzing and on one I can pretty much pin point it to the top 12" of the ribbon. I havent listened closely to the other ribbon yet to determine where its problem area lies.
I just dropped over $500 on these, someone tell me this can be fixed. Both ribbons look immaculate.
Post Tue Jun 29, 2010 2:29 am
Re: Ribbon buzzing
marantzfan wrote:I just acquired some ALIII ribbons to replace the damaged ribbon in my Amazing Silvers. I figured best to keep the matched type together then have one ALIII ribbon and one Silver ribbon.
Crap, Sorry to hear that - I think if everything looks good and no magnets are out of place there may have been at one time and a poor repair job that may look good could be the issue but I have no idea just a thought I too am in need of a Ribbon for my AL III's but on my bad one you clearly can see the magnet pushing against the Film and the pressure may have put a tear where I can't see - I may put super glue on a pencil and glue it to the out of place Magnet until it dries, Then pull the magnet away from the Ribbon so I can take the structure apart and re-glue the Magnet and look for rips.
If you see no issues at all maybe a easy fix will pop up!
Post Tue Jun 29, 2010 2:37 am
Re: Ribbon buzzing
^ Unlikely
The climate change IS most likely the problem, and the fact that they are probably 10-20 years old.
Did the person you bought them from say anything about them ever being rebuilt?
The FIRST thing I would try is, close up the house and turn the AC on for a day or 2, (get it down to 75) and it will probably go away.
If it does, turn the AC off, and you will have to start tightening screws (( A LITTLE AT A TIME )) and see if you can get the buzz to go away.
If you can't, then you have bigger problems, and could be looking at a rebuild.
marantzfan
Post Tue Jun 29, 2010 3:38 pm
Re: Ribbon buzzing
^ Unlikely
Thanks for the reply Toymaker. Once I begin tightening screws how will I know when is enough and when is too much?
I really, really don't want to have these rebuilt or I will have more money in these then it would have costed to buy OEM ones from you. [-o<
Also, I don't think these have ever been rebuilt.
Breaking Glass
Post Tue Jun 29, 2010 11:00 pm
Re: Ribbon buzzing
I have some original 30” ribbons I replaced with a set of 60” from Toy maker, with the original 30” ribbons I felt that with some interments (mainly woodwinds or electronic pop like Enigma) they would emit a slightly unnatural sound when I first got my amazing speakers but I keep my house closed up, the ac on and a dehumidifier running all the time to insure low humidity. You could hear the speakers getting better and better the longer they were in this environment and it pulled some of the moisture out of them. Of course now I have the 60” in them and a stack of 30” setting off to the side, maybe one of these days I will get around to making something out of them.
Post Wed Jun 30, 2010 12:34 am
Re: Ribbon buzzing
Make TINY, 1/16th-1/8th adjustments to the screws nearest the buzz. If you hear a "pop"....oh shit. The ribbons screws are the Philips head; the square head are for the ribbon attachment to the wings.
marantzfan
Post Wed Jun 30, 2010 2:39 pm
Re: Ribbon buzzing
Wel....So far, so good. Tightened up the screw in the areas I could hear the buzzing and for now, no buzzing!! One on ribbon it was actually buzzing in two places so I had to tighten screws in two areas.
Fingers crossed that I fixed it and the problem doesn't resurface. [-o<
Post Wed Jun 30, 2010 3:51 pm
Re: Ribbon buzzing
cool..... \:D/ \:D/ \:D/ \:D/ [-o< [-o<
Post Wed Jun 30, 2010 4:33 pm
Re: Ribbon buzzing
Congrats =D> =D> =D> =D>
Post Sun Aug 29, 2010 1:18 am
Re: Ribbon buzzing
so do either of you guys that have the a stack of 30" ribbons, or the al's and silvers want ot part with a ribbon or two for cheap. i want to make a center channel to go with my al-III's for the ultimate 7.1 surround sound. i think that the two 30" might do good as i can have some kind of tweeter between them. but i am not too picky. i am going to use some midbass drivers and woofers along with a horn of some sort. i tried a al-III sideways as a center, but it did not sound correct. it sounded like a tv speaker on steriods, and not like a bad ass center channel like in a theater.
marantzfan
Post Sun Aug 29, 2010 1:01 pm
Re: Ribbon buzzing
angelod307 wrote:so do either of you guys that have the a stack of 30" ribbons, or the al's and silvers want ot part with a ribbon or two for cheap. i want to make a center channel to go with my al-III's for the ultimate 7.1 surround sound. i think that the two 30" might do good as i can have some kind of tweeter between them. but i am not too picky. i am going to use some midbass drivers and woofers along with a horn of some sort. i tried a al-III sideways as a center, but it did not sound correct. it sounded like a tv speaker on steriods, and not like a bad ass center channel like in a theater.
I have an extra Silver ribbon which I have posted for sale on this forum.
viewtopic.php?f=126&t=12420
Post Tue Sep 07, 2010 7:54 pm
Re: Ribbon buzzing
"SOLD" \:D/
