It is currently Sat May 18, 2013 11:58 am
Questions for Bob @ CarverFest 2010
Post Tue Sep 07, 2010 9:02 am
Re: Questions for Bob @ CarverFest 2010
F1nut wrote:
TFM any amp on the cheap
It still won't sound like a tube amp.
85% there though for $1.50 :lol:
Post Tue Sep 07, 2010 12:30 pm
That's like only running 85% of a race because it didn't take as long as going the distance. You still didn't finish.
Post Tue Sep 07, 2010 12:52 pm
Yeah, but you saved gas~
Post Tue Sep 07, 2010 1:06 pm
See above
bwaahahahahahahaha
a little laugh at your expense Mr. President
Jesse, you run SS amps with a tubed front end, right?
Post Tue Sep 07, 2010 4:05 pm
He sho' 'nuff do. It sounds phenomenal too. =D>
Post Tue Sep 07, 2010 9:14 pm
I just ate 3 burritos, I don't need to save any gas.
Post Tue Sep 07, 2010 9:19 pm
Magnaryder wrote:Jesse, you run SS amps with a tubed front end, right?
In one rig, which also includes a tube output SACD/CD player. The other rig is 100% tubes.
Thanks Tom, I appreciate the kind words. I've actually done a few things since you heard it last and believe it or not, the sound quality took a major step up.
Post Wed Sep 08, 2010 7:08 pm
No burritos for Jesse at Carverfest!
Post Wed Sep 08, 2010 9:29 pm
1:what is your take/view on whether SS electronic components need to age (hours) to sound better? Ie: caps in speakers, preamps...etc
2:how do the opp amps of yesteryear compare to today's? what would you do different if you had to redo some products?
Post Mon Sep 13, 2010 11:08 am
Was it Bob's intent and/or did Bob modify all of the TFM (transfer function modified) series of amplifiers to sound the same within their design criteria? :-k
Post Wed Sep 15, 2010 3:06 pm
Bob, if you can.......please tell us a little bit about the new sub design [theory] that you are currently working on. I have heard about it and all I can say is that, once again, you are definitely thinking outside of the box.
Post Wed Sep 15, 2010 4:43 pm
+1 :!:
Post Fri Sep 17, 2010 3:34 am
boy, i can't wait for this. i ready already....
Ed Marimba
Post Sat Sep 18, 2010 8:55 am
After listening to the phono board that Brian has,,,,can a stand alone "box" be built for those of us who might want one?
Post Sat Sep 18, 2010 10:28 pm
Ed Marimba wrote:After listening to the phono board that Brian has,,,,can a stand alone "box" be built for those of us who might want one?
Good question, that would be an awesome option for sure. :-k
Return to CARVERFEST 2010
