Sun Mar 06, 2011 9:51 am by tinpan
The glass shelves look great. That is one hell of a set up. I have always wanted to display a rack of Carver amps like that but never seemed to make it happen.
I have a vertical Phase Linear 400 and pre-amp that would look great in the right side of your rack
Just curious what DAC's you and OO are using. I noticed a huge difference when I added a Cambridge Audio Magic Dac vs the analog outputs on the Apple TV. Then I upgraded the Cambridge to an Eastern Electric DAC and it had a different sound, which I liked. Now I am using the AN DAC and am pretty settled on that config.
One thing I did do though, is recently I down loaded a copy of Pure Music. It has a 15 day trial period. I have noticed a big difference using that instead of iTunes to play my music. I thought iTunes was wonderful until I tried PM
I have no troubles with imaging and projection when playing digital music. i wonder why you are seeing a difference?
Just something to maybe try.
I think OO has a Benchmark DAC, come to think of it,
