It is currently Wed May 22, 2013 8:29 am
Carver Plats vs. Martin Logan Vantage--*Help*
jck
Post Mon Jun 06, 2011 10:32 pm
I'm looking at both but am a fan of carver. Its been 20+ years since I listened to a pair of AML...
I have the room, amp, etc. I need suggestions, input, value...etc
Post Tue Jun 07, 2011 7:24 am
Re: Carver Plats vs. Martin Logan Vantage--*Help*
Personally, for the money, I would take the Amazings.
Post Tue Jun 07, 2011 11:23 am
If you can afford BIG MLs, go for it, but Amazings, especially Plats, are dollar-for-dollar far better. You have to spend the really big bucks to get equivalent performance elsewhere.
Post Tue Jun 07, 2011 12:31 pm
I looked around for the Plats for a year or so mainly just to fit in with the crowd here. I had no luck and was about ready to buy the ML ESL Motion speakers.
I recently got a pair of these instead: http://www.definitivetech.com/products/products.aspx?path=Speakers%20By%20Series|Mythos%20Series&productid=Mythos%20ST%20SuperTower
To me they sound good. I have and have had a lot of speakers, but none like this. I think they are a good example of speaker science improving over the years, as well as materials.
The true test of speakers (and systems) for me is not just to play loud, but to play at low levels accurately.
These are in a large room. If I took you in blind folded to the middle, I doubt you could point to the speakers as I have them about 20 foot apart and the sound stage is huge, room for the entire orchestra to have a seat.
I was intending to buy ML ELS Motion and a better sub than my Polk MicroPro 1000. I got a deal on these Def Tecs, and at least for me, have no need of a sub now at all. I have the Polk hooked in, but since this is just for music, it is mostly dead. So you could factor not needing a sub into the cost. You do have to run a power cord to each speaker.
These are tall enough for the high and mids to be above pool table height, and the low end below that is not a sonic problem. The are heavy speakers, so finding their place in the room is no fun. :lol:
I am very happy with these after a couple weeks. It is hard now for me to think I could have made a better choice. It is also good to know these would also be happy if I ever acquire a tube amp which might be lower power since on my budget Bob's Black Beauties are out - :lol:
You can NEVER have it all in one system, so everyone must eventually make choices, and that means choosing priorities.
Anyone who says otherwise is either very ignorant or lying.
- Arthur Salvatore
Dimensions | Metric :51-1/2" H x 9-1/2" D x 6-3/4" W | 130.8 x 24.1 x 17.1 cm
Height with Base | Metric :53" | 134.6 cm
Base Dimensions | Metric :11-1/2" W x 15-5/8" D | 29.2 x 36.5 cm
Driver Complement :One 1" pure aluminum dome tweeter; Two 5-1/4" BDSS midrange drivers; One 6" x 10" long-throw racetrack subwoofer pressure coupled to two 6" x 10" long-throw racetrack radiators.
Frequency Response :14 Hz – 30 kHz
Impedance :Compatible with 8 Ohms outputs
Sensitivity :93 dB
Recommended Associated Amplifier Power :20 – 350 watts
A/V Receiver Crossover Setting :Large; Full Bandwidth
Internal Amplifier Power :300 watts
Auto On / Off :Signal Sensing (US) | Signal Sensing and Switched (International)
Power Requirements :110 volts Alternating Current (US) | 220 volts Alternating Current (International)
Inputs :One pair of 5 way binding posts; One LFE input (optional)
Fuse :3.2 amp 250 volt Slo Blo (US) | 2 amp 250 volt Slo Blo (International)
Enclosure :Aircraft grade extruded aluminum
Available Finishes :Gloss Black
Base :Granite
Accessories :Plastic foot tippers; Isolation spikes
Packaging :One to a carton
Weight | Metric :80 lbs | 36.3 kg
Warranty :5 Years; 3 Years for Amplifiers
Post Tue Jun 07, 2011 3:40 pm
BillD wrote:If you can afford BIG MLs, go for it, but Amazings, especially Plats, are dollar-for-dollar far better. You have to spend the really big bucks to get equivalent performance elsewhere.
That's about it in a nut shell. I sold my Plat's but only cause I am stuck with a place that does not have the room for them anymore. If I ever move I will get another pair cause they do everything well and most other speakers lack something where Plat's do not.
Post Tue Jun 07, 2011 4:27 pm
Agree 100%. Speak from experience. I had to spend really big bucks to do better than my Plat 4's as mains. Now using them as dual center channels. Plat's just don't bring enough on the used market to justify letting them go for this ole boy. They do everything pretty darn good: from lows to highs, not to mention vocals and the mid-range, where they really shine. Been part of the family since new.
Post Tue Jun 07, 2011 4:44 pm
HOLY FUCK...dual Plats as a center channel??? What in the hell do you use for Mains???!?!!????
Post Tue Jun 07, 2011 5:12 pm
TNRabbit wrote:HOLY FUCK...dual Plats as a center channel??? What in the hell do you use for Mains???!?!!????
Silly Wabbit,
These are what replaced my Plat's as mains after 18 years or so:
http://www.legacyaudio.com/index.php?It ... item_id=93
http://stereomojo.com/Legacy%20WhisperX ... Review.htm
Post Tue Jun 07, 2011 5:36 pm
OconeeOrange wrote:I looked around for the Plats for a year or so mainly just to fit in with the crowd here. I had no luck and was about ready to buy the ML ESL Motion speakers.
- Arthur Salvatore
Sensitivity :93 dB
Base :Granite
Double 0,
Heard a pair of DT Mythos in South Florida. Bought a pair of used PSB Stratus Gold I's from the gentleman that he replaced the Mythos with. Just listened to them for a casual few minutes. But quick take, they sounded very nice, open and airy. Nice soundstage.
Was anxious to get back on the road, so it was a quick pick up and out.
Post Tue Jun 07, 2011 7:38 pm
Where you been Gary???? Old news......
Martin1970
Post Wed Jun 08, 2011 8:45 am
I remember waiting patiently for Don to get those Whispers so I could try to buy his perfect set of plats.
There probably won't ever be someone that close to Savannah thinking about selling a set that nice.
At least not in my lifetime.
Then he decided to center-channel them.
And his wife let him!
Talk about the luckiest man alive...
Rane: RPM88 26Z x3
rah
Post Wed Jun 08, 2011 10:16 am
Silly Wabbit,
Do you have pictures of your setup?
My office (and only) system:
Carver TD-1770
Klipsch Chorus II's
Legacy Studio's (circa 2003)
Sony CA70ES 5-disc changer
Sony SACD 5-disc changer
Post Wed Jun 08, 2011 3:14 pm
Martin,
One of these days I am going to talk Bill D. into sending me a Legacy Marquis HD center channel to compare against my Plats if we can sharpen the pencil enough. If I like the blend of the Marquis HD center channel with my Whisper XD's over the Plats, I will keep you in mind. It is very hard to part with a family member that has been so good to me over the years. I suspect The Marquis HD will have a tall order.
http://www.legacyaudio.com/index.php?It ... item_id=11
Rah,
I really don't know how to send pictures that are not gigantic. Not real computer literate. Eddie was kind enough to re-size them for me last time.
Currently waiting for Direct TV to come to house and add another HD receiver so things are a bit array right now as my home run is behind my 67" Sammy. One of these days I will get on the stick and learn a bit more regarding the upload to the site and re-sizing. Other priorities right now with Mother in Law in declining health and in facility.
Post Wed Jun 08, 2011 3:39 pm
*deleted*
Post Wed Jun 08, 2011 3:40 pm
Don wrote:One of these days I am going to talk Bill D. into sending me a Legacy Marquis HD center channel to compare against my Plats if we can sharpen the pencil enough. If I like the blend of the Marquis HD center channel with my Whisper XD's over the Plats, I will keep you in mind. It is very hard to part with a family member that has been so good to me over the years. I suspect The Marquis HD will have a tall order.
I think you've got the wrong guy. I wish I had the Legacy as a center, though. Maybe there's another Bill D. around. Maybe at Legacy?
