It is currently Fri May 24, 2013 3:11 pm
EXPLAINING TUBE AMP TYPES
• Page 1 of 1
Is there anybody here that can explain push-pull, singled ended, and OTL (output transformerless ) amplifiers. My knowledge if these amps died with a few brain cells.
Re: EXPLAINING TUBE AMP TYPES
I know this is an old post- but this may help Snoop-
http://en.wikipedia.org/wiki/Valve_audi ... _technical
Yeah...but SE does not typically have enough power to drive my Apogees.....
Wow, I forgot about this thread. Thanks for the reply!
Zoot Horn wrote:this guy has a sense of humor,,SE vs PP
http://homepage.mac.com/tlinespeakers/v ... wnloads/SE
Link does not work--->
Looking for something on MobileMe?
We can't find the page you requested. Please make sure the URL is spelled and capitalized correctly, and try again.
MobileMe Login | MobileMe Support | Learn more...
Sie suchen etwas auf MobileMe?
Die angeforderte Seite kann nicht gefunden werden. Vergewissern Sie sich, dass die URL richtig geschrieben ist, und versuchen Sie es dann erneut.
MobileMe-Anmeldung | MobileMe-Support | Weitere Informationen...
Que cherchez-vous dans MobileMe ?
Nous ne trouvons pas la page que vous avez demandée. Vérifiez que vous avez saisi correctement l'URL et utilisé la casse appropriée, puis réessayez.
Connexion à MobileMe | Support MobileMe | En savoir plus...
MobileMeで何かお探しですか?
お探しのページが見つかりません。スペルや大文字・小文字などURLが正しく入力されているか確認し、再度お試しください。
MobileMeログイン | MobileMeサポート | 詳細はこちら...
© Copyright 2011 Apple Inc.
で何かお探しですか?
Thanks! Good stuff-
• Page 1 of 1
