Re: Post here and let us know you made it home safely
Eddie wrote:I am home safe and sound! The CWB tryed to get a ride from me at the first VA rest stop going north!!!!!
Eddie "the knife" You know better. Stay away from that CWB!
It is currently Fri May 24, 2013 10:52 pm
Bunni wrote:Anders said someone took a pic of him with Bob...if whomever you are would please post that. I'd be eternally grateful
OconeeOrange wrote:angelod307 wrote:
Angelo, screw that, get some pics up.
I have a few of you and others. I will get some up this week. Who has the one of The Bob Father with my wine? That photo might make for a good label -
Bunni wrote:Anxious to know if Brian made it home ok...Anders did thanks to him
BrianT wrote:Bunni wrote:Anxious to know if Brian made it home ok...Anders did thanks to him
Bunni.
I made it back to Ottawa, around 1:15 am total return distance 3867km.
Stayed in bed until 9:00am and then started to unpack.
Set up my Silver 7's tube amps to find they both have hum's in them with or without RCA line feed connected, any idea's ?
They do sound very, very nice, a good purchase.
Hope to see you all next year.
Brian.
Keep us posted as to your progress!Chauss wrote:Brian,
Are you running "conditioned" power source? It sounds like it may be a ground loop....maybe try a 2 prong adapter to eliminate ground and see if that helps? If not--send them here and I will investigate for you,,,it may take until next CarverFest to get them back to you though!Keep us posted as to your progress!
Even those little APC units at the cabins would work for that- the battery in the UPS "filters" the power- they were selling them for @ $100.
Chauss wrote:Good deal Brian! Sounds like there may be a power conditioner in your future...Even those little APC units at the cabins would work for that- the battery in the UPS "filters" the power- they were selling them for @ $100.
http://blueguitar.org/new/articles/other/ground_loop.pdf
Cheers!~
TNRabbit wrote:Proper audio cable connection methods are essential in getting hum free system. Rane technical note Sound System Interconnection is a very good source for information how the audio wiring between equipments should be connected. This is a well worth to read article.
http://www.rane.com/note110.html
TNRabbit wrote:Dangerous method: break the mains ground connections
Logically you could think, you could eliminate ground loops by disconnecting the power-cord ground pins on all your gear. Some people might try to break the ground connection by cutting the grounding pin in the connector, using cheater plug, cutting the ground wire in equipment, taping over the grounding connector etc.
Do not do this. Removing the ground connection isn't right.
