It is currently Wed Jun 19, 2013 2:10 am
Cant download pics
Post Fri Sep 23, 2011 12:13 pm
Re: Cant download pics
Thanks Wayne, George had Toms SDA 1C's at the fest . I also had a pair of 1C's at the fest and we were going to do an A-B comparison of my pair and Toms modified pair but it just never happened. I do like the sound of my polks in my bedroom so much so that I set my sights on finding a pair of the BIG ones which is what I purchased yesterday. Harry
Post Fri Sep 23, 2011 4:32 pm
SRS or SRS tl's ??????????
Post Fri Sep 23, 2011 6:47 pm
how many mid-bass and how many tweeters?
Post Fri Sep 23, 2011 11:17 pm
You may have to convert the image if you ant upload at all - what file extension is showing up? There are programs to convert the photo if you have to. I will walk you through it if you need. Next time check what format your camera saves the photos in and see if you can change it.
Do you know I have a "Book Of Slights" in my head? Everyone who has ever slighted me is in there. It's a BIG book...but payback is a bitch.
Post Fri Sep 23, 2011 11:21 pm
Roy, not sure which version they are . Tom wants me to post a photo and he and Jesse will try to figure out what they are.
George, 4 tweeters and 8 midbass drivers with a 15" passive radiator.
Post Sat Sep 24, 2011 1:02 am
Since it says SDA SRS along with a low serial number they are indeed SDA SRS's. They will have SL2000 or RD0194-1 tweeters and a blade/blade SDA cable.
Post Sat Sep 24, 2011 4:44 am
Congrats on the new aqusition,,now the fun begins =D>
Post Sat Sep 24, 2011 6:49 am
Congrats Harry
Post Sat Sep 24, 2011 9:33 am
Here are some pictures
Post Sat Sep 24, 2011 10:35 am
Important: Do not use mono block, dual mono or a non-common ground amp with those speakers.
Post Sat Sep 24, 2011 10:48 am
Ed Zachary.
Post Sat Sep 24, 2011 10:54 am
Jesse, I did notice that the bottom tweeter on both speakers appears different from the other 3 is this normal or has someone replaced with the incorrect tweeter?
Post Sat Sep 24, 2011 12:33 pm
from the pics they look the same to me. 2000 is a bright speakers, if you like bright, then stick to the 2000's. Do all the speakers work? 1.5tl can run them fine.
Post Sat Sep 24, 2011 12:51 pm
The Sl 2000 should be the stock tweeter,,the replacements are the RDO 194,,much better then the sl 2000's IMHO--enjoy
Post Sat Sep 24, 2011 5:55 pm
hewlew1 wrote:Jesse, I did notice that the bottom tweeter on both speakers appears different from the other 3 is this normal or has someone replaced with the incorrect tweeter?
They look exactly the same to me.
Return to CARVERFEST 2011
