CarverFest 20w Tube Amp Schematics & Pictograms
AlexSauter
Site Admin
Post by AlexSauter » Thu Sep 22, 2011 4:23 pm
Bob asked me to post the most updated schematics and pictograms for those that took home incomplete copies. If you are going to build your amps at home, please go by these diagrams!!!
If you click on the images they get a little bigger, if you need a larger image, I can email poster sized images.
*****DO NOT FOLLOW THIS DRAWING, USE THE AUTOCAD VERSION I DREW*****
(Stereo System)
Carver Pro PT-1800
Logitech Squeezebox
Post by treitz3 » Thu Sep 22, 2011 4:29 pm
Ah, are these the "final" version 121.2 or 123.7? O:)
Re: CarverFest 20w Tube Amp Schematics & Pictograms
Post by Zoot Horn » Thu Sep 22, 2011 4:50 pm
Thank you Alex. =D>
WhackJob
Post by WhackJob » Thu Sep 22, 2011 6:05 pm
Thanks for sharing that!
I've been out of the loop for a bit, are any of the components used custom or hard to get?
Looks like a great winter project. \:D/
jerryj12
Post by jerryj12 » Thu Sep 22, 2011 6:29 pm
Thanx Alex ! You tha Man.
Post by hewlew1 » Thu Sep 22, 2011 7:29 pm
FYI, Bob had recommended not using the (2) 7.5 volt Zener diodes in the biasing network as his opinion of them is that they were of inferior quality. If you overheat them or in my case if they fail on thier own you will indeed experience the plates glowing red hot in the output tubes (6BQ5). He later suggested to me that he recommended a 17 volt 2 watt zener to replace them. I have not yet sourced a replacement diode. Harry
Post by BillD » Thu Sep 22, 2011 7:39 pm
THIS MIGHT BE OVERKILL
but it would work
AlexSauter
Site Admin
Post by AlexSauter » Thu Sep 22, 2011 8:12 pm
WhackJob wrote:Thanks for sharing that!
That winter project may become a year long project, we called the company that made the Transformers for Bob, and they told us that they were custom made for Bob to Bob's specs, we can't even get them without Bob's permission.
(Stereo System)
Carver Pro PT-1800
Logitech Squeezebox
WhackJob
Post by WhackJob » Thu Sep 22, 2011 8:32 pm
Dang!
Post by TNRabbit » Fri Sep 23, 2011 3:38 pm
Alex, I toastedone of my switched IEC outlets..any chance you have a spare? If not, where did you get them?
AlexSauter
Site Admin
Post by AlexSauter » Fri Sep 23, 2011 4:41 pm
TNRabbit wrote:Alex, I toastedone of my switched IEC outlets..any chance you have a spare? If not, where did you get them?
I only have 2 left for Wayne's amp, we got them off eBay straight from china.
(Stereo System)
Carver Pro PT-1800
Logitech Squeezebox
AlexSauter
Site Admin
Post by AlexSauter » Thu Sep 29, 2011 10:52 pm
I have been reworking the Pictograms so that they are easier to follow, I went off of my Amp (because it works flawlessly) instead of the Pictogram that I got from Bob, so if there are differences, please give me a little time to cross check the two.
(Stereo System)
Carver Pro PT-1800
Logitech Squeezebox
Post by Chauss » Fri Sep 30, 2011 8:23 am
Nice work Alex!!! =D> =D> =D>
Post by kingman » Fri Sep 30, 2011 8:45 am
ATTA BOY!!! =D>
Post by engtaz » Fri Sep 30, 2011 10:23 am
Thanks Alex
Return to “CarverFest 20w Tube Amp”
