Wiring question
Ray
It is currently Sat May 25, 2013 11:23 pm
wrstps wrote:Have a question about wiring speakers in Parallel. Can speakers be wired by putting the pos lead to the first speaker and running a wire from speaker 1 to the pos terminal on speaker 2 while doing the same with the ground? In other words all of the pos to pos and ground to ground then connecting the leads from the amp to the last set of speaker spades. Or do I have to run separate leads to all spades.
Ray
wrstps wrote:So the silvers are wired in a combination of Series/ Parallel? Any one got a diagram for dummies? or can you call me to talk me through this. Thanks.
Ray
](./images/smilies/eusa_wall.gif)
