It is currently Tue Jun 18, 2013 6:12 pm
Wiring question
wrstps
Post Mon Oct 31, 2011 11:53 pm
Wiring question
Have a question about wiring speakers in Parallel. Can speakers be wired by putting the pos lead to the first speaker and running a wire from speaker 1 to the pos terminal on speaker 2 while doing the same with the ground? In other words all of the pos to pos and ground to ground then connecting the leads from the amp to the last set of speaker spades. Or do I have to run separate leads to all spades.
Ray
Post Tue Nov 01, 2011 12:20 am
Re: Wiring question
Are you wiring subs? Mains?
Post Tue Nov 01, 2011 1:29 am
Re: Wiring question
anyway you like. from speaker to speaker or from the terminal to the speakers.
AlexSauter
Site Admin
Post Tue Nov 01, 2011 1:55 am
Re: Wiring question
wrstps wrote:Have a question about wiring speakers in Parallel. Can speakers be wired by putting the pos lead to the first speaker and running a wire from speaker 1 to the pos terminal on speaker 2 while doing the same with the ground? In other words all of the pos to pos and ground to ground then connecting the leads from the amp to the last set of speaker spades. Or do I have to run separate leads to all spades.
Ray
Hey Ray,
It looks cleaner when going from speaker to speaker rather than from one terminal to each speaker. We asked Bob that same question while he was down here in FL before CarverFest. If you decide to run individual wires from each speaker to the terminals, keep in mind the resistance of the wire, we first used 22 ga wire and had a .3 ohm resistance in just the wire! You wouldn't believe the difference it made going from 22 ga wire to 20 ga wire?
RIP BillD
(Stereo System)
Carver Pro PT-1800
Sunfire Prototype TGA-2375
Carver TX-2 Tuner (not used)
Post Tue Nov 01, 2011 4:39 am
Re: Wiring question
Assuming they're the same type speaker, you'll cut the impedance in half that way (two 8 ohm will become 4 ohm).
wrstps
Post Tue Nov 01, 2011 8:22 am
Re: Wiring question
The wiring is for my silvers, I got a wild hair last night and started looking at diagrams of speaker wiring and noticed none of the pictures showed the wires going to the spades as mentioned in the original post. Thanks for all the help.
Ray
Post Tue Nov 01, 2011 8:29 am
Re: Wiring question
The impedance will depend on exactly how you wire them- here is a good link to help explain the various ways:
http://www.rocketroberts.com/techart/spk_wire.htm
Series Parallel is what you want in order to keep the impedance the same as the crossovers were designed for.
Cheers!~
wrstps
Post Tue Nov 01, 2011 11:32 am
Re: Wiring question
So the silvers are wired in a combination of Series/ Parallel? Any one got a diagram for dummies? or can you call me to talk me through this. Thanks.
Ray
Post Tue Nov 01, 2011 11:56 am
Re: Wiring question
wrstps wrote:So the silvers are wired in a combination of Series/ Parallel? Any one got a diagram for dummies? or can you call me to talk me through this. Thanks.
Ray
Almost ALL multiple-speaker systems are wired in a series of parallel runs. However, since the SIlvers are an odd-number (3), they are wired in parallel, out of phase to the crossover.
I found these threads in a 2-minute search:
search.php
viewtopic.php?f=15&t=1516&hilit=silver+woofer+parallel+series
Details:
The Silver series Amazings have three, 16 ohm, 12" woofers. There are several iterations of the CROSSOVER, however; the main being the T or CT version. They are wired together in parallel to produce a (approx) 4 ohm load. If they were the more conventional 8 ohm woofers, they would represent a 2 ohm load which would present a tremendously difficult load. The crossover ties the ribbon/woofers together to give you an approximate 8 ohm load overall.
So, to recap, you need to wire the woofers in parallel out of phase with the crossover, and the ribbon in phase with the crossover. The phase differences are addressed within the crossover.
Post Tue Nov 01, 2011 4:32 pm
Re: Wiring question
Thanks Rabbit! My bad- thought there were 4 drivers..... ](*,) ](*,) ](*,)
Post Tue Nov 01, 2011 5:11 pm
Re: Wiring question
Now that I think about it...they may be closer to 6 ohms....of course it's all relative as it changes with frequency & temperature.
Post Tue Nov 01, 2011 8:15 pm
Re: Wiring question
16/3=5.3333333333333333333333
wrstps
Post Tue Nov 01, 2011 10:22 pm
Re: Wiring question
After doing a lot of reading and research today it appears that the correct way to wire a pair of silvers is to use 12 gauge wire and the three subwoofers should be wired out of phase with the ribbon and in parallel. Anyone have any more things I should look out for? And thanks for all the help.
Ray
wrstps
Post Wed Nov 02, 2011 8:47 am
Re: Wiring question
Could someone tell me where the neg wire on the silver ribbon is connected? is it directly to the neg terminal on the amp connections or is it connected to a spade on a woofer. Thanks.
Ray
Post Wed Nov 02, 2011 10:12 am
Re: Wiring question
I think only the Silver CT-type woofers are wired out of phase with the ribbon. The non-CT type are not.
CT Type
agxovrCT copy.GIF (8.11 KiB) Viewed 632 times
Non CT-type
