It is currently Tue Jun 18, 2013 8:54 pm
Carver amp for 2 18" 8 ohm subs
Post Thu Dec 08, 2011 3:23 pm
Re: Carver amp for 2 18" 8 ohm subs
Kingman, I do have a question for you.
I will be running this amp as well as ALL my other gear off one circuit (assume its a 15 amp circuit as well). As I am renting having more circuits run isnt really something I want to look at.
If I keep the gain low on this amp can I run it off the same circuit as my other gear?
Post Thu Dec 08, 2011 4:00 pm
EndersShadow wrote:Kingman, I do have a question for you.
YES!!! If you keep the volume below deafening level it will work, but if you drive it hard a couple of things can happen..1) Lights dim as the circuit is over drained 2) Fuses in you panel will blow as too much current is being drawn. 3) Power will be limited to the current the circuit can provide so headroom will be diminished. Don't worry too much though...I have all mine run through a 15 amp circuit and have never blown a fuse although a brown out occurs on a regular basis!!! :lol: :lol: :lol:
Post Thu Dec 08, 2011 4:32 pm
kingman wrote:a brown out occurs on a regular basis!!!
I don't even want to ask! =; =; :lol: :lol: :lol: :lol:
Post Thu Dec 08, 2011 4:35 pm
Cool, I figured as much. As this is an apartment I dont figure on running ANYTHING 100% volume lol. I dont get above 50 (out of 75) on my Integra when watching movies so I doubt I would be even at 1/4th the gain on that amp with those subs...
Now my only problem is figuring out how I would run the connections since I would have 3 amp connections (AV705x + PT2400's) off the 2 High Current outlets on my H15 #-o #-o
Post Thu Dec 08, 2011 4:50 pm
  Code:
...2 words...power strip. 8)
Post Thu Dec 08, 2011 4:51 pm
  Code:
LOL, yeah but I hate to do that. Might need to just invest in something like this: http://signalcable.com/magicextension.html
Post Thu Dec 08, 2011 4:55 pm
Same deal just fancier. Don't use a power conditioner as it will limit the current draw to the amp.
Post Thu Dec 08, 2011 5:07 pm
kingman wrote:Same deal just fancier. Don't use a power conditioner as it will limit the current draw to the amp.
I was planning on running it along with the AV705x through my APC H15 (which I know will limit the current, but it has voltage regulation and surge protection)...... hence my comment about connecting 3 plugs to 2 connectors (the H15 has 2 high current outlets)
Post Thu Dec 08, 2011 5:19 pm
...all Carver amps are designed to be plugged directly into the wall. No need for a conditioner....henders the current pull=NOT GOOD!!!!
Post Thu Dec 08, 2011 5:23 pm
I am aware, but if we get hit by a power surge then I just lost both amps and more than likely the speakers connected to them... thats darn near 3k in gear....
I have used the 705x both plugged directly into the wall, and in the H15 and noticed no difference at the volume levels I listen at.
Post Thu Dec 08, 2011 5:46 pm
Post Thu Dec 08, 2011 5:50 pm
kingman wrote:In reality, it only matters what it sounds like to YOU!!!
Yup, that is a true statement. Numbers/spec's dont matter if they dont sound good to you. Trust me when we purchase a house I am going to have a breakout panel installed strictly for my HT stuff so I can run it all off that, and will be putting a whole home surge protector on the box, running the amps on their own circuit and the rest of the gear off a different one.
Post Thu Dec 08, 2011 9:06 pm
Good for you...and in the mean time purchase a good power strip. Cheap insurance.
