It is currently Wed Jun 19, 2013 4:45 am
TFM-75 serial#00001
Post Mon Feb 06, 2012 10:41 pm
Re: TFM-75 serial#00001
i use, as well as many others use, a pound of fill to the cubic foot of air space. a little more and it dampens a bit more, like 20-24oz to the foot and in the end you trade efficiency for lower tone as the fill will mimmick a larger box than is there. i would also, although a little harder now, put a brace or two on the side walls to back wall, as well as side to side. the more solid the sides, the more output you get that the box itself doesn't absorb up and again the lower it will play without the flexing sucking up the lowest notes. the braces are only relavent if you play it loud, really loud even though you might notice it at lower volumes as well. a rta will show it easy like. and because i did not say it in the first part of the post, very nice work by the way. daddy likes...
Post Mon Feb 06, 2012 11:29 pm
I have one filled and one not. At first I havent noticed much diference. I even used the AudioControl warble tone mic and tested the db readings from right to left @ 31.5hz. without much difference between them. Gonna have to play with it a little more to see what is working best.
To mount these speakers first take off the outer aluminum ring.
Then remove the inner stainless ring.
Then fold uip the rubber surround and expose the holes for drilling in the wood screws.
Post Mon Feb 06, 2012 11:48 pm
Heres a few pics of the final product. Turned out great and the bass reproduction is unreal! The windows upstairs vibrate and distort slightly when you look at them in the sun light...lol
Post Tue Feb 07, 2012 4:44 am
=D> =D> =D> =D> =D> =D> Very nice work. Congrats
Post Tue Feb 07, 2012 8:30 am
Good job!!! Enjoy the music!! =D> \:D/ 8)
Post Tue Feb 07, 2012 11:29 am
Just wait until you get the TGP-II in the mix, everything from the bass response all the way up should improve quite noticeably!! :D :D
Post Sat Feb 11, 2012 11:31 pm
Got the isolation spikes installed. And built some billet aluminum pads to set them on.
Post Sun Feb 12, 2012 2:52 am
You've got skills. Schweet
Post Sun Feb 12, 2012 2:02 pm
Looks like a system that really COULD blow back your hair re that old seventies ad for Pioneer stereo (or some such system from that golden age of hi-fi). Happy extreme listening. Hope your neighbors understand that LOUD is an addiction that must be fed (and a TFM-75 can definitely dish it out!)! :lol:
Post Sun Feb 12, 2012 2:30 pm
I tell ya this setup has almost unlimited bass. I turned it up last night way past what I thought the speakers could handle and it just got LOUD and more clear. The 75 was just idleing not even sending the needles to half way.
Im now fully hooked on Carver crack and just bought a Sunfire 600x2 from a forum member. Looking at the RE Audio 18XXX subs to be run by the 600x2. These subs weigh 115lbs.
The wife is probly gonna kick me out of the house soon :lol: :lol:
Post Mon Feb 13, 2012 10:28 am
Wow, that whole set up looks nice
Post Tue Feb 14, 2012 12:03 am
Thanks! I got the Sunfire TGP II hooked up now.
Post Tue Feb 14, 2012 11:08 am
Lookin' good. You might want to be careful stacking so much gear, I'd hate to hear about dented / damaged top covers etc. looks like you've got 100lbs sitting on the TFM-75 right now all bearing down on the four little feet of the PT2400. Did you notice a difference with the new Sunfire preamp? :-k
Post Tue Feb 14, 2012 1:09 pm
I have just been thinking about that very thing. Gonna start looking for a system rack or maybe make one.
The Sunfire pre has a much warmer tighter sound. Its hard to explain...you can just hear the quality in it. It has so many options I havent used a fourth of them yet. :lol: :lol:
Post Fri Apr 13, 2012 10:18 am
Got some dedicated lines under way \:D/ Should pull around 105+amps at max power just from the amplifiers. :lol:
