It is currently Sat May 25, 2013 5:56 am
MRHP's cave dwelling area
Post Tue Jan 10, 2012 11:58 pm
Re: MRHP's cave dwelling area
ready for the end of it all,.... :-" :-" :D :D
I see you got almost as much ammo as I have.... :lol: :lol: :lol:
wouldn't it be nice to own the real thing?????? :D :D :D
I have a FAL with a heavy barrel to build....
have an SKS that takes true AK clips, these guns are even simpler than a AK, truly a drag it thru the mud and it will still fire.
try that with an m-16.... ](*,)
by the way......
mmmmm,..... good man cave
Martin1970
Post Wed Jan 11, 2012 12:34 am
I'd love to hear a set of DQ-20s one day.
Where are you getting your surrounds from?
All I can find for the DQ-8s are foam surrounds,
and they're supposed to have rubber.
Rane: RPM88 26Z x3
Post Thu Jan 12, 2012 4:57 am
Great Pics.
Post Thu Jan 12, 2012 8:56 am
=D> That's a TRUE MAN CAVE if I ever saw one! =D>
Post Fri Jan 13, 2012 10:20 pm
Nice!! =D> =D> =D>
Post Mon Feb 20, 2012 12:17 am
Here is my current setup. The 10's guzzle up power big time. I turned the gains wide open on the 75 for the first time ever.
Post Mon Feb 20, 2012 11:53 am
MRHP wrote:Here is my current setup. The 10's guzzle up power big time. I turned the gains wide open on the 75 for the first time ever.
I'm surprised the speakers are still sitting there!! They must be power hungry all right. I'd have thought wide open on the TFM-75 would have blowed em up Real Good!! :lol:
Post Mon Feb 20, 2012 3:50 pm
My thoughts exactly Doug. I had a pair of 10's and anything above 200 watts per was danger territory. It' s time you get that rack going for those components, that's alot of weight on the 75.
Post Mon Feb 20, 2012 5:12 pm
:lol: :lol: Running the 9's and 10's together = 16 total drivers so I guess its enough to use up alot of the 75's power. I havent turned the volume much past half, but let me tell you at about half throttle it gets LOUD!! with plenty of headroom.
Kingman did you blow anything on your 10's. I had this thing cranked a couple times and have never hear a cymbal crash that loud. I know its time to get the rack built, been looking to buy one but nothing suits me. I took everything off of it and there's not a mark on it but definately too much weight.
Post Thu Mar 01, 2012 11:49 am
Here is the vintage livingroom setup.
Post Thu Mar 01, 2012 3:03 pm
...Just fuses. I liked them but they did not suit my needs at the time.
Post Thu Mar 01, 2012 10:57 pm
You need more speakers! :lol:
Post Thu Mar 01, 2012 11:18 pm
Well I have already changed the living room system.
Me and my mechanic fixed the Marantz mono blocks.
Pulled the Carver CT-6 out.
Yamaha KX-670 cassette deck.
Audio Control eq. ($24 on ebay) \:D/
Dahlquist DQM-5 speakers
Post Thu Mar 01, 2012 11:24 pm
Just trying to load all these amp down in the 2 to 3 ohm range :lol: :lol: I like it loud and clear \:D/
When I want to do some serious laid back audiophile listening I just use on pair of mains at a time. Should be fun to roll tubes trying all different typs of speakers.
Post Fri Mar 02, 2012 11:06 am
I like the TV stand, kind of a cool vintage look to go with the silver faced gear.
If you like LOUD and clear music, I highly recommend looking into some Klipsch Chorus IIs. I've had a set for the past few years and they are very hard to beat, extremely loud, clear and the type of bass that kicks you in the chest!! :D :D :D You can run these with a 2 watt tube amp or the Sunfire 600x2, they're easy like that! There's a nice pair on eBay right now:
http://www.ebay.com/itm/110832659104?ss ... 710wt_1185
