It is currently Sat May 25, 2013 12:02 pm
Carver Lightstar Reference - 4 sale
Post Wed Apr 18, 2012 10:46 pm
Re: Carver Lightstar Reference - 4 sale
kingman wrote:Hey Tom...what's the chance of asking the cabins to install a 30 amp dedicated cuircuit in one of the cabins or maybe 2 so we could really find out the limits of the "Super" amps? :-s
Better yet...why don't we gather up the wire and sufficient breakers and do it ourselves? We could run a so called drop cord of wire with a plug in attached directly from the breaker box.... that way it's temporary... :shock:
I have about 100' of spare 10 gauge 4-wire. That shit is EXPENSIVE! I think I can scrounge a 30-amp breaker, too.
Excellent!!! I say we chip in and make this happen!!! Gary...I'm gonna hold you to coming this year!!! You will be in charge of wiring the circuit!!! \:D/
Post Thu Apr 19, 2012 1:50 am
We need to know what type of breaker panel they have to get the correct breaker. Cutler-Hammer?
Post Thu Apr 19, 2012 6:05 am
Think like Bob.
Tap straight off of the transformer.
Be like Bob. :D
Post Thu Apr 19, 2012 7:36 am
Re:
treitz3 wrote:Think like Bob.
Be like Bob. :D
Sorry, not exposing myself to thousands of volts for no good reason~
Post Thu Apr 19, 2012 8:25 am
Re: Re:
Be like Bob. :D
You are sooo right!!!! Tom...will you call the cabins to see what kind of boxs they run????? I don't know why this hasn't been thought of earlier!!!!! :?
Post Thu Apr 19, 2012 2:00 pm
I once attached a pair of 2-gauge jumper cables to the mains & hooked a pigtail to the other end.....I don't recommend it & will certainly never do that again~
Post Thu Apr 19, 2012 4:26 pm
Buncha wussies! I work beside those transformers every day! I was only kidding, though. :) I'm sure Duke Power wouldn't like us "stealing" power from them, which is exactly what will happen if we tap straight off the transformers. You can always tap after the meter but that's the same thing as using the breaker.
As far as asking the cabins what type of circuit breaker they use? I'm not so sure that would be a good idea. If all we need is one of two types of breakers, I would buy both of them and return the unused one after Carverfest.....or just get the one we need while we are up there.
Post Thu Apr 19, 2012 7:59 pm
What ever you guys do be careful messing with electricity. I don't want you to end up like this guy!
Post Thu Apr 19, 2012 8:40 pm
OUCH!!! :shock:
Post Thu Apr 19, 2012 10:39 pm
Re: Re:
TNRabbit wrote:Exposing myself for no good reason~
Gary I fixed it. Lol hehehe
Post Thu Apr 19, 2012 11:08 pm
ther's always a good reason to expose ones self..... :D
Post Mon Jun 11, 2012 5:59 pm
So what happened to the Lightstar Angelo? Did you ever hear back from the guy?
gdb
Post Mon Jun 11, 2012 10:03 pm
As an alternative to buying breakers, why not just either tie into a dryer recep or get a plug of the same type as the dryer's and make an "extension cord". You could also "re-task" an existing high amp breaker in the panel temporarily. :-" Edit just make sure to keep voltages the same, split the "legs" for 230v circuits.
Post Mon Jun 11, 2012 10:04 pm
Snoop65 wrote:The Lightstar is over built and dual mono. It's also a awesome sounding. I have never heard the Sunfires but I have been told that they don't sound as good as the Lightstar.
I'll bet you $100 you can't tell the difference in a blind test.
Bet you I could just going off of memory. [4 years old at this point] :wink:
Return to Buy/Sell/Trade for Newbies
