It is currently Tue May 21, 2013 10:20 pm
M-500T light burn out
ribbonspeaker
Post Thu Apr 19, 2012 12:15 am
Do you know who can replace the lightbulb and how much ?
Post Thu Apr 19, 2012 9:40 am
Re: M-500T light burn out
Rita at Bob Carver's Audio Service here in Snohomish should be able to fix it. I believe the minimum fee is $120 but that includes bench testing, inspection and re-calibration.
http://ritasvintageaudio.com/index.php/ ... 3-10-38-05
Post Thu Apr 19, 2012 11:00 am
Shit! Don't do that!!!! I will send a link later with a solution. Playing golf....
ribbonspeaker
Post Thu Apr 19, 2012 1:06 pm
Thank Kingman. I know you have the solution for it. 120$ to replace the lightbulb ?
part 1.35 ?
please help.
Post Thu Apr 19, 2012 3:59 pm
Keep in mind that amp is 30 years old, if it hasn't been re-calibrated or serviced you can cause major damage, just sayin' :-s
ribbonspeaker
Post Thu Apr 19, 2012 5:55 pm
Thank for the advice.
Post Fri Apr 20, 2012 7:41 am
ribbonspeaker wrote:Thank Kingman. I know you have the solution for it. 120$ to replace the lightbulb ?
part 1.35 ?
please help.
You can probably find one at this link... http://www.kenselectronics.com/lists/lites.htm
ribbonspeaker
Post Fri Apr 20, 2012 9:13 am
Thank a bunch kingman.
Do you think the wedge light bulb 8.3v 250MA should work ?
Post Fri Apr 20, 2012 1:17 pm
In the service manual it says 8 volt .25 amp....I believe you have the correct one...
