It is currently Sat May 18, 2013 8:33 am
hello
allaboard1970
Post Wed May 23, 2012 1:45 am
hello
God i am so happy ... :D .never new this site was here.searched 4 carver products & info 4 a long time with little 2 no results.. at last i have found you..i bought a cm 1090 integrated amp in the early 1990s & have been in luv ever since ...sounds amazing...i have a pair of AAL223s that have sounded great 4 years but now the foam arround the 4 12" woofers has detiriated..doesnt sound so good anymore & my amp keeps kicking out,im asuming its because of the speakers.any advice as 2 what 2 replace the woofers with on a limited budget ?
Post Wed May 23, 2012 4:08 am
Re: hello
Welcome
Post Wed May 23, 2012 6:52 am
Re: hello
Welcome to the forum.
Post Wed May 23, 2012 8:24 am
Re: hello
I would suggest buying some re foam kits for the speakers. Look at Parts Express or several other places on line. Good luck!
Post Wed May 23, 2012 9:43 am
Re: hello
Welcome to the forum!
Post Wed May 23, 2012 10:07 am
Re: hello
Welcome...you are gonna love it here! I had some AAL's on my first system, they sounded great with those big ole paper woofers.
I sent some woofers here thanks to forum member jjptkd:
"Around the sound" in Seattle does great work. I've had numerous Klipsch speakers re-coned there over the years. The guy has been in business over 30 years.
(206) 782-7975
323 N 105th St Ste C
Seattle, WA 98133
Post Wed May 23, 2012 10:13 am
Re: hello
WELCOME!!!!! \:D/ \:D/ \:D/
Post Wed May 23, 2012 3:10 pm
Re: hello
If the amp continues to cut out (I assume going into protection) you need to check the inputs on the speakers with a multimeter for resistance/impedance..you may have burned a coil.
Post Wed May 23, 2012 3:32 pm
Re: hello
hello
kco_321
Post Wed May 30, 2012 10:23 am
Re: hello
Hello Carver people,
I have enjoyed reading all your post for a while even though some of it is over my head. I aspire to accumulating alittle of your expertise as time goes on.
I have several Carver pieces that I rotate in and out of use and I have some I would love to get working to their full potential :)
Thank you all for your invaluable insights and advice and your dedication to keeping these great contributions to Audio alive n well.
KC
Post Wed May 30, 2012 4:21 pm
Re: hello
Welcome
Post Wed May 30, 2012 6:13 pm
Re: hello
=D> \:D/ =D> Welcome!! \:D/ =D> \:D/ Sorry to hear about your speakers. There's a couple options available if you cannot find or afford replacement woofers. You could find new foam surround kits (assuming the foam rotted) and fix them yourself or you could have the drivers re-coned. The re-coning option isn't exactly cheap, $60-$75 each woofer but they will be original spec and like brand new. You want to stick with original woofers if you replace them or they might not sound right. Hope this helps, good luck!
Post Wed May 30, 2012 11:43 pm
Re: hello
kco_321 wrote:Hello Carver people,
KC
Welcome! You should start your own thread and make it official....take some pics of you system and post them in your thread. We all like pics!
kco_321
Post Thu May 31, 2012 1:48 am
Re: hello
oppps.. my bad.. I'll do that :)
Post Thu May 31, 2012 9:55 pm
Re: hello
hello.
Return to "The Welcome Mat"
