It is currently Fri Dec 15, 2017 3:08 am
mrjazz1959
Post Sat Jun 16, 2012 10:53 am
Post Sat Jun 16, 2012 12:37 pm
Re: TFM-45
1. Yes
2. Yes
4. Yes, Japan
Oppo Sonica DAC / Pre
Post Sat Jun 16, 2012 12:39 pm
Re: TFM-45
Post Sat Jun 16, 2012 12:59 pm
Re: TFM-45
Mine too.
Post Sat Jun 16, 2012 1:03 pm
Re: TFM-45
Mine too.
They all do. :-$ :-$ :-$
mrjazz1959
Post Sat Jun 16, 2012 3:08 pm
Re: TFM-45
Thanks
Post Sat Jun 16, 2012 8:35 pm
Re: TFM-45
Post Sat Jun 16, 2012 10:44 pm
Re: TFM-45
Post Sun Jun 17, 2012 12:42 am
Re: TFM-45
Post Sun Jun 17, 2012 10:02 am
Re: TFM-45
mrjazz1959
Post Sun Jun 17, 2012 2:32 pm
Re: TFM-45
mrjazz1959
Post Wed Jun 20, 2012 4:28 pm
Re: TFM-45
Found some info on damping:
Source 1 says:
Source 2 says:
Post Wed Jun 20, 2012 10:05 pm
Re: TFM-45
