It is currently Mon May 20, 2013 1:59 pm
490t tube change time??
Post Wed Jun 27, 2012 8:13 pm
Re: 490t tube change time??
Chauss wrote:Snoop- you know what MY favorite 12AX7 is! :D
MRHP - keep an eye out on eBay- there are a lot of Fisher tubes that were made by TFN that can be had for much less $'s.
The TFN's seem to produce a much wider sound stage than other 12AX-7's I have tried. Have FUN rollin!
Nice to see you back Chauss! I agree with you nothing in the 12AX7-5751 family makes a larger soundstage than the Telefunkens and I don't think they can be matched in detail
Post Wed Jun 27, 2012 11:14 pm
I take it your favorite is the TFN :D So do you like the smooth plates or ribbed :-k
And just to be sure... I need to look for Fisher labeled 12AX7's??
Post Thu Jun 28, 2012 9:15 am
Yes Telefunkens labeled Fisher. Look carefully though because Fisher used other tube manufacturers other than Telefunken.
Post Thu Jun 28, 2012 3:54 pm
Smooth plate- West German manufactured.
They made them all over the place later as the tooling was sold many times over the years(Czechoslovakia, Yugoslavia, Great Britain, France,etc...).
Here is the holy grail TFN 12AX7 tube (usually 100 bucks a pop with good life left)
http://www.ebay.com/itm/Telefunken-ECC803S-OldStock-12AX7-ECC-803S-/170867397493?pt=Vintage_Electronics_R2&hash=item27c87d9375#ht_1981wt_1397
Here is a Fisher 12AX7 TFN made tube. (2 are West German TFN - 1 is Mullard -Great Britain)
http://www.ebay.com/itm/3pcs-Fisher-Telefunken-12AX7-ECC83-Tube-Tested-Germany-x2-Great-Britain-x1-/130717173487?pt=Vintage_Electronics_R2&hash=item1e6f59c6ef#ht_1373wt_1166
The mark of a real TFN tube is the <>(raised diamond) on btm of the tube below the plate- so if ever in doubt- ask for a pic of the btm of the tube from the pin end. To my knowledge only the original tooling had that logo in the mold.
Have a blast rollin!
~Cheers!~
Post Thu Jun 28, 2012 8:17 pm
Trust that old fart Chauss, HE KNOWS!!!!!! :D :lol:
Post Thu Jun 28, 2012 10:01 pm
I bet you those 803s tubes go for about $700-800.
Post Thu Jun 28, 2012 11:21 pm
Snoop65 wrote:I bet you those 803s tubes go for about $700-800.
=P~ =P~ =P~ =P~
They are on my watch list....but if they go that high I might let 'em pass. :lol: :lol:
Post Thu Jun 28, 2012 11:31 pm
=P~ =P~ =P~ =P~
Some tube stores sell the 803S for as much as $1400 a tube.
Post Fri Jun 29, 2012 10:40 am
WOW!
What do you guys do with left over tube once you find that perfect combo??? Do you sell them on ebay, to friends, give away??? I have some orange globes, jan phillips, etc that probably wont be used again.
Post Fri Jun 29, 2012 2:31 pm
MRHP wrote:WOW!
All the above. Some I keep for back ups. They sound good , its just the ones I use in the preamp sound better.
Post Fri Jun 29, 2012 8:42 pm
Just hold on to them if they are NOS or lightly used NOS....prices have not been going down! :D
Post Fri Jun 29, 2012 11:03 pm
Chauss wrote:Just hold on to them if they are NOS or lightly used NOS....prices have not been going down! :D
There you go! Chauss with the good advice as always! :D
Post Sat Jun 30, 2012 11:10 am
So have you guys played with 12AX7 Mullards? Looks like I can pick up a fairly cheap pair of Fisher Mullards to try as well.
I bought a nice pair of the RTC E188CC Mullards to try in my preamp and 490t and really like them. My DQ20's are a little bright and they toned everything right down without losing any detail, 3-D, etc. I use them in the 490t when playing CD's and in V2 and V3 when using phono.
Post Sat Jun 30, 2012 1:25 pm
Chauss has some Mullards and he let me try them out. Nice tubes. Good soundstage and nice warmth.
Post Sat Jun 30, 2012 1:29 pm
Mullards are nice- a bit more "reserved"- but sometimes you need that! :D
I also like RFT's 12AU7's - the ones with the RAMs head logo made in East Germany- they are a good bit brighter than the Mullards, but town down to just right after @ 50-75 hrs usage. Have fun rollin! The trick is finding the best combo for YOUR gear- as it tends to differ from one amp manufacturers circuit design to the next. ~Cheers!~
RAMS head logo here:
http://tubemaze.info/rft-12au7-angled-getter/rft-12au7/
You can find these on eBay from time to time for @ 35-40 bucks a pair.
