It is currently Sat May 18, 2013 4:39 pm
Carverfest Amps & Khorns finally
Post Mon Jul 16, 2012 11:28 am
As some of you may be aware, I acquired these 1954 Khorns a few months back. I was going to flip them but they match my car so I decided to keep them. The only problem though was the bass didn't sound good at all. My first amp was the Audio Note 300b SET integrated. That amp sounds wonderful on my Altec A7's but doesn't produce any bass on the Khorns. Then I tried my piece of junk Goldox 300b pushpull tube amp and the bass started showing up.
That amp ended up in my garage so next up was the Sophia Baby amp. It sounded ok, I think that amp sounds better on my KG4s but that was what stayed on the Khorns for a few months.
I finally decided to give the Carverfest amps a go on the Khorns. Wow, I think I finally found the match. The bass is finally alive, the midrange is warm and detailed and highs are there as well.
Finally this set up is coming together. These are running mono block but I think one amp in stereo mode would would be all I need.
Still need a preamp but using the Grant Fidelity DAC is working ok for now. Cable management 8-[ ?
One of these days I'll put the metal faceplate on, these are Eucalyptus amps stand I made, although I think I'll change the feet on them.
Anyway, I am glad I finally put these amps on these speakers. I know a lot of folks talk about 300b tunes on a Khorn, don't know why but these sound a lot better.
Post Mon Jul 16, 2012 6:26 pm
Re: Carverfest Amps & Khorns finally
Congrats Tinpan! K-Horns are some great speakers, had a pair forever ago and do miss them! =D>
Post Mon Jul 16, 2012 6:30 pm
Very nice!! =D> =D> I must admit, there's not often times I'm green with envy but this is definitely one of them... =P~ =P~ =P~ =P~
Post Mon Jul 16, 2012 6:34 pm
Cool, tinpan! Always nice to hear a success story!
Post Tue Jul 17, 2012 9:59 pm
jjptkd wrote:Very nice!! =D> =D> I must admit, there's not often times I'm green with envy but this is definitely one of them... =P~ =P~ =P~ =P~
what he said!!!!
