Preamp choices for the tube amps
Any suggestions on this guys?
It is currently Wed Jun 19, 2013 9:54 am
nooshinjohn wrote:The amps sound fantastic when run through the Pioneer, but lack any sparkle at all when played with the Sunfire. The initial tap on a cymbal, and the resulting decay are completley missing, and my Maggies have a 6 foot tall ribon in them! verything else apppears to be good from the bottom up through the mids.
I am going with some Bugle Boy 12AT7's and Telefunken smooth plate halo getter 12AX7's and see what this does for the amps. hopefully this wakes up the upper end. If it does, then I will be putting the Sunfire back in the mix.
TNRabbit wrote:Sounds like there's a problem somewhere. Are you using the same interconnects with the pioneer and sunfire? Perhaps There is some kind of Impedance mismatch...
stereo_buff wrote:Did you say whether or not you were listening to vinyl when you noticed the 'lack of sparkle'? I noticed something similar when listening to LPs (using an MM cartridge) until I replaced the 5751 (12AX7) on the phono PCB of my Sunfire Tube Preamp. According to Bob, the circuitry requires every bit of gain available from the 12AX7 (the 5751 is a ruggedized 12AX7, but with slightly less gain, according to Bob; 30% less, according to Tube Depot), In addition, Bob told me that the frequency response on the bottom end was also slightly degraded when using the 5751 in the phono circuitry. Replaced with an Amperex 12AX7 and everything was cool.
Snoop65 wrote:stereo_buff wrote:Did you say whether or not you were listening to vinyl when you noticed the 'lack of sparkle'? I noticed something similar when listening to LPs (using an MM cartridge) until I replaced the 5751 (12AX7) on the phono PCB of my Sunfire Tube Preamp. According to Bob, the circuitry requires every bit of gain available from the 12AX7 (the 5751 is a ruggedized 12AX7, but with slightly less gain, according to Bob; 30% less, according to Tube Depot), In addition, Bob told me that the frequency response on the bottom end was also slightly degraded when using the 5751 in the phono circuitry. Replaced with an Amperex 12AX7 and everything was cool.
Which 5751's were you using?
