It is currently Tue May 21, 2013 5:35 pm
305 tube rollin
Post Mon Aug 20, 2012 6:47 pm
Re: 305 tube rollin
angelod307 wrote:
Angelo.
Look like another vote for the Psvane 12AX tube's
VPI Classic Turntable (blk)
Carver Silver 7's Tube Amps
Carver TX11.
B&W 802D's Rosenut
Post Mon Aug 20, 2012 9:58 pm
Re: 305 tube rollin
yup. just for fun, i just bought/got a telefunken 12ax7 made in w.germany for 42 shipped. my sonic frontier only needs one tube, and curiousity killed the cat you know. so, i will have a some tubes for rolling at the fest in the pre and then the psauve for the jolida. as i have two jolida's, it should be easy to a/b them.
Carv-it-up
Post Mon Aug 20, 2012 11:55 pm
Re: 305 tube rollin
I have tried several sets of tubes in the Cherries.
Re-issued Gold Lion 12ax7 & 12at7
Re-issued Tung Sol 12ax7 & 12at7
Pavane T series 12ax7 & 12at7
NOS Mullard CV4004 & CV4024
ALL the tubes were very good. The GL's were an all around nice sounding tube. I’ve read scores of folks who believe them to be the-cats-meow, but they come in 2nd place for me. For the price, the TS's were good and sounded as if they had the highest gain, but were a little bright; they took 3rd place. The P's took the cake. The sound from top to mid-bass is outstanding (bass in my system is run by a Sunfire CG Signature); they take 1st place. The NOS M's are a bit of a speciality tube for me. It's midrange is is is mmmmm maaagical. The top end is a little on the softer side, which I’m ok with. What made/makes the M’s difficult for me to grade is that they are like a novelty item or sound, it's great for a while, but then...
The output tubes are KT 120’s. I tried the stock tubes that come with the Cherries, but when I cranked up the volume the stock tubes looked so distressed…blue and orange flames violently pulsating to the demands of the current hungry mid/tweet towers of my Infinity Beta IRS’s. The KT 120’s handle the “cranking” so much better.
I will occasionally look to acquire other tube sets to roll, but for now the Pavanes will run in my Cherry 180's.
It’s interesting that the NOS sound Better to a lot of folks. It would seem that the new or re-issued tubes would out perform the old tubes. My thinking is this…the older tuber were designed for everything electronic. The new tubes of today are designed specifically with audio in mind.
This is my first go ‘round in the tube world, so be understanding of any naivete I may have shown with this post.
Carv-it-up
Post Tue Aug 21, 2012 4:45 pm
Re: 305 tube rollin
Thanks angelod307. I'll stick with the 12ax7 and 12at7 tube configuration the way Bob designed it to be.
Post Tue Aug 21, 2012 9:54 pm
Re: 305 tube rollin
sweet and juicy like these nutz.
Post Wed Aug 22, 2012 8:24 pm
Re: 305 tube rollin
Angelo- sounds like almost too good a deal... I hope they are real TFN's-
Telefunken ECC83
A well known tube among audiophiles and guitarists, some people regard the Telefunken ECC83 as the ultimate pre-amp tube. It is used more commonly by audiophiles. The Telefunken is considered a wide-band 'neutral' or 'clear' tube. It does not really impart any color to the sound. Therefore, if you have an overly warm stereo or guitar amp, you may want to consider this tube. There are two main types of Telefunkens: smooth plates and ribbed plates. The smooth plates are usually more desirable and expensive for audiophiles, probably because people consider this type to be more 'neutral'. Telefunkens are not used in guitar amps as much as other ECC83 types. I have found that the smooth plate Telefunken lacks personality in a guitar amp and does not really overdrive well. The ribbed plates are a little better in this regard. However, there is a good place to put a Telefunken smooth plate in a guitar amp... in the phase-inverter slot (usually the last slot closest to the power amp tubes.) I have found that this can add some 'clarity' and '3-D' effect to your overall sound. Genuine Telefunkens always have an etched diamond shape on the bottom of the tube between the pins, so you must always look out for this. Telefunkens are also commonly faked, even with the diamond bottom. Usually these fake Telefunkens will have perfect labeling that is 'baked-on' and will not rub off with a cloth. This is a dead-giveaway that you are dealing with a fake. The labels on real Telefunkens are always fragile and will easily rub off. Look out for Telefunkens with other labels: Fisher, Gap-R Computor and others. These are genuine Telefunkens and can usually be had at special prices. There are also highly regarded 'Lab Quality' Medial Telefunkens that were produced for Leeds & Northrup Grummond. These will usually have red tips, say 'Selected' somewhere on the tube, and are sought after by audiophiles who will pay insane prices for these tubes.
Post Wed Aug 22, 2012 8:48 pm
Re: 305 tube rollin
Chauss has spoken! :D =D> =D> =D> =D> =D> =D>
