Damn, CF amps making Phoomfp Phoomfp sounds
Post by tinpan » Wed Sep 05, 2012 11:58 am
I had these running on my Khorns and they sounded perfect. Today they made a little Phoompf sound so I cut them off and hooked up a pair of test speakers. They played fine for about an hour and then they started making a Phoomfp Phoomfp sound again. No smoke or fire. The tubes look fine but it definitely sounds like something letting go.
Any ideas before they see the great trade in UPS truck?
Re: Damn, CF amps making Phoomfp Phoomfp sounds
Post by hewlew1 » Wed Sep 05, 2012 4:39 pm
Are these Carverfest amps or are the the new production models just released by Bob. I thought I remember seeing where you traded up.
Post by TNRabbit » Wed Sep 05, 2012 5:17 pm
hewlew1 wrote:Are these Carverfest amps or are the the new production models just released by Bob. I thought I remember seeing where you traded up.
He traded the stainless steel pair up. He still has the first two I built....for now...
Post by Chauss » Wed Sep 05, 2012 8:21 pm
I would start with the power supply circuit.
Return to “CarverFest 20w Tube Amp”
