It is currently Sat May 25, 2013 1:05 pm
TFM-55 power dial lights stopped working
brit01
Post Sat Sep 08, 2012 5:37 pm
Hi guys,
Been a while since I've posted anything here.
Recently my 2 cluster lights on the front panel have stopped working. Both at the same time so I assume it's not just a blown light.
Can anyone assist me with re-illuminating my needle power dials on the front panel? It's juts not the same without that nice glow behind the fluctuating needles.
(I'm suspesting it's the misses fault due to her pulling the plugs out of the wall without swtiching off the amp first!! ](*,) )
Thanks
Post Sat Sep 08, 2012 6:06 pm
Re: TFM-55 power dial lights stopped working
Did you accidentaly hit the dimmer switch button on the front?? Otherwise, I'd say it IS the lamps if the meters still work. Kens Electronics sell these as Galaxy radio lamps cheap.
brit01
Post Sat Sep 08, 2012 6:19 pm
even on the dimmer the lights don't work.
Are they in series so if one goes the circuit is cut?
I'll whip off the top and test their resistance out with the DMM.
Thanks
p.s no Kens here I'm afraid. What specs do they have? (voltage/watts)
Post Sat Sep 08, 2012 11:26 pm
Welcome back! Are you still in S. America?
Many folks have done an LED mod to increase lifecyle hours on the meter lamps. Sounds like your issue is not burned lamps, but might be something to do while you're in there....
Post Sun Sep 09, 2012 6:46 am
brit01 wrote:even on the dimmer the lights don't work.
Thanks
http://www.kenselectronics.com/lists/lites.htm#axial
Toddroberts
Post Fri Dec 21, 2012 12:08 am
TNRabbit wrote:Welcome back! Are you still in S. America?
Many folks have done an led bulbs mod to increase lifecyle hours on the meter lamps. Sounds like your issue is not burned lamps, but might be something to do while you're in there....
I am looking to purchase led lights for my car. Do you know any reliable source?
