Eq, bbe sonic maximizer, and tube buffer wiring
cring08
Post by cring08 » Wed Oct 10, 2012 6:12 pm
I just wired up my living room in the new house.
I have a question on the best way to wire, specifically the tube buffer.
Right now, I have the eq running through the mxr tape loop, and the bbe through the eq loop.
I have the CD player running to the tube buffer, and then to the mxr.
Any thoughts? #-o #-o
Living Room/main System:
Onkyo tx nr 545
Carver Amazing Silvers
Carver SD 390t
Technics SL 1950 Turntable
Polk Audio outdoor speakers wired to deck
Polk audio wired to pool table room
Basement/system 2:
Carver MXR-130
Teac reel to reel
BBE 362 Sonic Maximizer
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Pioneer 100 disk changer
Garage system:
Pioneer VSX something?
Polk Audio 2500
Re: Eq, bbe sonic maximizer, and tube buffer wiring
Post by TNRabbit » Wed Oct 10, 2012 9:30 pm
I personally wouldn't run an EQ AND a BBE unit together.
But that's me.
cring08
Post by cring08 » Thu Oct 11, 2012 11:35 am
TNRabbit wrote:I personally wouldn't run an EQ AND a BBE unit together.
But that's me.
Why?
I guess I could run them through seperate tape loops to compare?
Onkyo tx nr 545
Carver SD 390t
Basement/system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Garage system:
Polk Audio 2500
Post by TNRabbit » Thu Oct 11, 2012 11:38 am
I didn't need my bbe after going active & installing the Rane parametric EQs.
Just my 2 cents~
Post by F1nut » Sat Oct 13, 2012 9:34 pm
Too much stuff in the signal path. If you really need all that to get good sound, you should consider starting over again with gear that doesn't require all that to sound good.
cring08
Post by cring08 » Sun Oct 14, 2012 8:00 am
F1nut wrote:Too much stuff in the signal path. If you really need all that to get good sound, you should consider starting over again with gear that doesn't require all that to sound good.
I have the mxr130 as my amp right now, and I am currently looking into upgrading to Sunfire or at least a carver power amp.
I guess I should rephrase my question. Without buying thousands in all new gear, how can I get the best sound with what I have?
I was also told(here on the forum)that the bbe would really enhance my amazings.
Onkyo tx nr 545
Carver SD 390t
Basement/system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Garage system:
Polk Audio 2500
Post by kingman » Sun Oct 14, 2012 9:34 am
Chris...if you are running 130 watts per into the Amazings then you are barely hearing them and lucky the receiver hasn't shut down. Is this what is happening or did I just misread the last post? :shock:
cring08
Post by cring08 » Sun Oct 14, 2012 11:34 am
kingman wrote:Chris...if you are running 130 watts per into the Amazings then you are barely hearing them and lucky the receiver hasn't shut down. Is this what is happening or did I just misread the last post? :shock:
No, it's running fine for now. I really was just wondering an the wiring scenario?
I do realize I need more juice to run these things!
What is the minimum power I should be putting to the amazings?
Onkyo tx nr 545
Carver SD 390t
Basement/system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Garage system:
Polk Audio 2500
Post by TNRabbit » Sun Oct 14, 2012 11:46 am
Minimum power is a very subjective thing. More importantly you need an amplifier that will source a lot of current.
Are you happy with sound the BBE unit gives you? That's all that really matters~
cring08
Post by cring08 » Sun Oct 14, 2012 11:50 am
TNRabbit wrote:Minimum power is a very subjective thing. More importantly you need an amplifier that will source a lot of current.
It seems to add depth? Maybe because I'm not pushing enough power?
Onkyo tx nr 545
Carver SD 390t
Basement/system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Garage system:
Polk Audio 2500
Post by TNRabbit » Sun Oct 14, 2012 12:16 pm
Personally, I think the BBE is nothing more than a simple EQ ( If you check the specs it boosts @ 50 Hertz and 8000 hertz IIRC).
That's 1 reason I don't think you need both units.
On the power side, can you reach your level of volume that you like without straining your receiver? Has it ever gone into protection shutdown because you were driving it hard? If not & you're happy with the sound, consider yourself lucky.
The AL-IIIs are a difficult load, mostly due to the passive crossover. An amp capable of putting a comfortable 600 watss at 4 ohms into them will get the most out of them. It all really depends on your common listening level & your expectations from a speaker.
I wohld definitely lose either the eq or the BBE. You don't need both.
Martin1970
Post by Martin1970 » Sun Oct 14, 2012 3:12 pm
TNRabbit wrote:Personally, I think the BBE is nothing more than a simple EQ ( If you check the specs it boosts @ 50 Hertz and 8000 hertz IIRC).
I always thought BBE was doing some EQ plus some phase shifting.
FWIW, I've got both EQ and BBE running on my plats.
Sounds good to me.
Post by TNRabbit » Sun Oct 14, 2012 3:18 pm
Sounds good to me.
I know they SAY it does, but I have my doubts. At any rate, it also has bass/treble boost.
cring08
Post by cring08 » Sun Oct 14, 2012 7:28 pm
Sounds good to me.
Mine sounds good as well. \:D/
But, time for more power...
Pm1.5
Pm900
M1.5
Tfm45
All on eBay reasonable cost,unless someone here has one for sale?
Onkyo tx nr 545
Carver SD 390t
Basement/system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Garage system:
Polk Audio 2500
