It is currently Wed Jun 19, 2013 7:41 pm
Bi amp Carver Amazing Platinums....
jonsoulman
Post Sun Oct 21, 2012 7:45 pm
My current system includes a Denon DP1000 with SME arm and MC cartridge (tweeked)
ARC SP 8
pair of ARC Classic 120s
All interconnects, power conditioning and speaker cable are Transparent.
I have three dedicated 20 amp circuits
Von Shweikert tower sub (powered with carver 800w amp)
Carver Amazing Platinum speakers.
I am currently using the passive crossovers in the Platinums with the "base" turned down completely and using the sub for fill below 100hz.
I want to bi amp the Amazings
Listening room is 24'x45' with a 20' vaulted ceiling and good base traps in back (behind listener) 24' wall
I have an ARC EC21 I could use for an active crossover.
Anybody have suggestions for crossover points and slope?
Any other suggestions?
Newbie here. First posting
J
Post Sun Oct 21, 2012 8:20 pm
Re: Bi amp Carver Amazing Platinums....
Most have made the crossover upwards of 200 hz, but I personally find the sound more pleasing when I keep it around 160-180 hz. I think the natural falloff of the ribbons to be about 165 hz.
Slope can be 6 dB/octave, but others have used higher slopes with good success. If you're crossover is selectable, you can play with it to find out what you like. FYI, every 6 dB will invert your phase 180 degrees.
You'll want to be able to adjust for ribbon delay to match the woofers (done passively in the passive crossover).
Martin1970
Post Sun Oct 21, 2012 9:21 pm
Here are my current crossover points. All crossovers are Linkwitz-Riley 24dB/octave.
The Amazing woofers are cut off at 50 Hz because they smoke badly at 100+ dB if you let them play lower. Letting the subs play up to 80 is a no-no, but it works in my tiny room for some reason, ymmv.
Welcome to the forum. Let's see some pics of your system.
Rane: RPM88 26Z x3
jonsoulman
Post Mon Oct 22, 2012 7:02 pm
Thanks for the quick responses. I have an Audio Research EC21 tube 2 way crossover with a mono bass output. I can figure out the crossover point around 175 or so but I don't know how to make that adjustment for the "ribbon delay". Am I to assume if I have a slope of 12db my phase will be normal? The ARC is not adjustable, I will need to do some soldering...(TNRabbit)
I like the idea of putting a floor on the 12" woofers since I have the VonSweikert (800w) pounding tight well below that 50hz.
That is a very impressive "wall of sound" (Martin1970)
Post Thu Oct 25, 2012 7:34 pm
Martin1970 wrote:Here are my current crossover points. All crossovers are Linkwitz-Riley 24dB/octave.
400w per/ch to the DQ8 tweeters?!?!?! If so, thats awesome! =D>
Post Thu Oct 25, 2012 11:55 pm
TNRabbit wrote:Most have made the crossover upwards of 200 hz, but I personally find the sound more pleasing when I keep it around 160-180 hz. I think the natural falloff of the ribbons to be about 165 hz.
i won't swear although i know many of the words, but , for every 6db it is 90 degrees out so 12 would be 180. i could and may be wrong. just what i remember from rockford fosgate traing in the late 80's.
Post Fri Oct 26, 2012 4:41 am
Thanks for the correction, Angelo. You are right.
Martin1970
Post Fri Oct 26, 2012 6:49 am
MRHP wrote:400w per/ch to the DQ8 tweeters?!?!?! If so, thats awesome! =D>
The fuses pop pretty regularly on tracks with lots of hf energy.
Really need to get a line of those tweeters or something.
You've got me beat with what you're doing with those 20s!
Rane: RPM88 26Z x3
Post Sat Oct 27, 2012 3:04 pm
Well thank you for the compliment, I would like to hear your system its interesting how you have it setup. What kind of crossover do you use?
Martin1970
Post Sat Oct 27, 2012 4:18 pm
MRHP wrote:Well thank you for the compliment, I would like to hear your system its interesting how you have it setup. What kind of crossover do you use?
It's a work in progress... needs a much bigger room/house.
The crossover is a Rane RPM-88 multiprocessor, kind of an audio Swiss Army knife.
Rane: RPM88 26Z x3
